Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
snakemain |
Oct 12 2016, 02:44 PM
Ronin Member Group: Members Posts: 577 Joined: 14-January 10 From: Aviano, Italy Member No.: 11,232 Region Association: None |
Here's the thread from when this topic came up a couple weeks ago.
http://www.914world.com/bbs2/index.php?sho...20&hl=turbo It can be done (turbo a type4, not 350 reliable hp...if you want those numbers go Suby or small block) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:10 AM |
