Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
Andyrew |
Oct 13 2016, 12:45 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
What are your limitations for your class in PCA racing?
stownsen914 |
Oct 13 2016, 02:20 PM
What are your limitations for your class in PCA racing? My car currently runs in the PCA Club Racing GT4 class (and where I'd like to stay), which is for highly modified cars using a Porsche tub as a base and a Porsche engine and transmission. The engine case needs to be a Porsche (or in this case VW) part. Pretty much every other part of the engine can be from any manufacturer. The GT classes use a sliding scale for displacement to weight, and different Porsche engines have different hp indexes. The aircooled 911 engine has a 110 hp/L index, 911 turbocharged is 210, type 4 is 90, and type 4 turbo is 150. Currently I run a 2.7L 911 motor in GT4. To remain in this class, I can have a turbo type 4 in the 1.8-2.0L range to run at the car's current weight of about 2100 lbs with me in the car. The type 4 has what may be a favorable index, if I can get 150-200 hp per liter, hence my inquiry. |
Lo-Fi Version | Time is now: 16th May 2024 - 04:31 PM |
