Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
Jetsetsurfshop |
Oct 13 2016, 03:10 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Does more boost mean more heat?
Can you run two smaller turbos with less boost? I don't know much about turbo. Throwing darts here. I like that Len knows the problem for the turbo idea. How can we solve it? The ceramic coating idea sounds good to me. What if you took a proactive approach and serviced the heads once a season? Race cars require this kind of service all the time. It's not like your trying to make a daily driver here. But then again, WOT does take its toll. |
stownsen914 |
Oct 13 2016, 08:23 PM
Does more boost mean more heat? Can you run two smaller turbos with less boost? I don't know much about turbo. Throwing darts here. I like that Len knows the problem for the turbo idea. How can we solve it? The ceramic coating idea sounds good to me. What if you took a proactive approach and serviced the heads once a season? Race cars require this kind of service all the time. It's not like your trying to make a daily driver here. But then again, WOT does take its toll. More boost is definitely more heat and stress on the engine. I understand that the advantage of smaller turbos is faster spool-up when you step on it. I think usually for a smaller motor, like 2.0L, most just use a single turbo. Maintenance would definitely be frequent on a turbo type 4! |
Lo-Fi Version | Time is now: 16th May 2024 - 01:10 PM |
