Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
Cracker |
Oct 13 2016, 08:40 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
This may not be popular, and I do not mean to be a "Debbie downer" but I think it is a disaster waiting to happen. Even under the best scenario (as is modern components and technology) turbo motors on the track are very expensive, tougher to drive, plagued with heat issues, and its tough to achieve reliably. The subies blow like its the fourth of July (on the track) - I've seen it "live" many a time. I'd never run one in anger (and they are light years ahead of a T4)! If you move forward, make sure you do so with the expectation that it will be "long road to hoe" (and expensive). Good luck in whatever you choose.
Tony |
Lo-Fi Version | Time is now: 16th May 2024 - 02:23 AM |
