Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
zig-n-zag |
Oct 15 2016, 02:23 PM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
FAT Performance does install 911 oil piston squirters in Type 4 cases, check with them.
I read somewhere that when using twin-plug ignition, there are more gains in power for smaller bores than with larger bores. It might have been written in the B Anderson 911 Handbook, or maybe in Up-Fixin...going by memory on this... I bought ARP thru bolts and ARP head studs. Jake recommends the head bolt torque be 24lbs, no mention of the case thru bolts. Gene Berg raised the case torque on Type 1s by spot-facing all the bolt holes and using thicker, hardened washers. An old article about engine builder John Zeitler increased thru bolt torque to 40lbs, perimeters 35lbs. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:22 AM |
