Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
Andyrew |
Oct 18 2016, 01:36 PM
Good results from a GT3076. Seems to me those are wheel numbers, which again is pretty impressive for a T4! You could find similar numbers for the Audi 1.8T guys.
Whats equally impressive is the torque curve. There is no boost spike, its straight linear. I cant tell from that first dyno sheet where the turbo makes max spool but Im going to guess its around 4k Just for reference the GT3076 is about the same size turbo as whats on my Audi 1.8T for those following my setup, and those are numbers I was expecting to hit myself on a much more advanced motor. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:51 AM |
