Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
HAM Inc |
Oct 19 2016, 08:45 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
O.P., can you convert to a T1 engine for your class?
If so find an aluminum Auto Linea case and build from that. There are plenty of new T1 head options out there that are stronger than T4 heads. |
Mueller |
Oct 19 2016, 09:13 AM
O.P., can you convert to a T1 engine for your class? If so find an aluminum Auto Linea case and build from that. There are plenty of new T1 head options out there that are stronger than T4 heads. Might as well do an LS1 if crossbreeding is allowed (IMG:style_emoticons/default/smile.gif) I think block needs to be "Porsche" (even if one considers the Type IV a VW motor) With the block needing to be Porsche even a 924 motor or a Macan motor would be legalish |
Lo-Fi Version | Time is now: 16th May 2024 - 05:12 PM |
