Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
ThePaintedMan |
Oct 19 2016, 09:31 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
I think for the amount of engineering involved and the very real possibility that a type 4 with that much boost on it may still be a grenade, I would consider another watercooled Porsche engine, as Mike suggested. What about a turbo 944 motor, or even a 928 V8? Those things can make some pretty healthy and reliable HP numbers without nearly as much $ or time as it would take to make the TiV work. All you need is a radiator and some water lines (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 08:22 AM |
