Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
Andyrew |
Oct 19 2016, 11:57 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
He needs to be in the 1.8 to 2.0L range to run a turbo.
If he went water cooled he could run a vw 2.0L block from a 924. Im not sure if a better designed DOHC head would fit on that block but that would be a killer setup and let you make a ton of potential power. |
stownsen914 |
Oct 19 2016, 12:10 PM
He needs to be in the 1.8 to 2.0L range to run a turbo. If he went water cooled he could run a vw 2.0L block from a 924. Im not sure if a better designed DOHC head would fit on that block but that would be a killer setup and let you make a ton of potential power. Interesting thought on swapping heads. PCA rules DO allow switching heads. Only the block has to be Porsche (or T4 or Audi/924). I'm probably showing my ignorance of 4 bangers here, but I wonder if a T1 head be massaged to fit on a T4 engine ... |
Lo-Fi Version | Time is now: 16th May 2024 - 06:16 AM |
