Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
ThePaintedMan |
Oct 19 2016, 12:47 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Well if you insist on the Type 4 route, it would probably be easiest to go to Wasserboxer heads then. No way the Type 1 heads would ever fit - dimensions are way different. With the WBX heads you could actually make that thing live, sort of like a 4-cylinder 962 engine... (IMG:style_emoticons/default/idea.gif)
Andyrew |
Oct 19 2016, 02:01 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Well if you insist on the Type 4 route, it would probably be easiest to go to Wasserboxer heads then. No way the Type 1 heads would ever fit - dimensions are way different. With the WBX heads you could actually make that thing live, sort of like a 4-cylinder 962 engine... (IMG:style_emoticons/default/idea.gif) I like the wasserboxer head idea. Run enough radiator and you can keep the damn thing cool for racing. You'll be generating a lot of heat with a turbo and really longevity is the key to racing. I dont think you should be shoveling into R+D on anything... Off the shelf parts and standard machining is the key IMHO. |
Lo-Fi Version | Time is now: 16th May 2024 - 05:31 AM |
