Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
HAM Inc |
Oct 19 2016, 01:07 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
If you want to go T4 and can swap to any head, find some Engine Plus heads. They were most popular in Europe.
As for T1 heads, like I said before; where there's a wallet there's a way. Because of the wider bore center of the T4 you'd want to start with a set of 4 individual heads, like the scats. They would then need major mods to work with the T4 bolt pattern and lifter spacing. Bring a big pile of $$ and a shovel. |
Jetsetsurfshop |
Oct 19 2016, 03:29 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
If you want to go T4 and can swap to any head, find some Engine Plus heads. They were most popular in Europe. As for T1 heads, like I said before; where there's a wallet there's a way. Because of the wider bore center of the T4 you'd want to start with a set of 4 individual heads, like the scats. They would then need major mods to work with the T4 bolt pattern and lifter spacing. Bring a big pile of $$ and a shovel. Think the Engine Plus heads will handle the heat? Did they move the exhaust port to the ends? Were they quality casting? I'm full of questions. (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 09:38 PM |
