Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
Jetsetsurfshop |
Oct 21 2016, 10:47 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Mueller |
Oct 21 2016, 11:06 AM
Unfortunately I would think that would be illegal in his class since not a "Porsche" block since they are brand new castings with a big Polopolus cast on the side of the block http://www.polomotor.com/ That would be smart move here and while it might cost more than the upcoming 718 watercooled 4 banger Boxster engine combo it will be much much easier since it will not be easy to run that new direct injection motor more or less standalone. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:44 AM |
