Turbocharging a type 4 |
Mueller |
Oct 19 2016, 11:52 AM
On the engine type, it has to be either Porsche block or an engine type that was supplied in a Porsche. So an Audi/924 engine or a T4/914 qualifies, unfortunately T1 doesn't. There is an option to do non-traditional engines like Cayenne, Macan, 928, 944, etc., but 2 things about that: 1. Switching engine/chassis type puts you into a different class (GTP) that basically no one runs in. 2. Doing a Cayenne, Macan, etc. probably would be even less economical than a T4, and at the moment those engines are not classified for PCA Club Racing. For those engines I'm not aware of off the shelf performance parts like camshafts, intake manifolds, etc. or that anyone has invested in learning how to extract power out of the heads. Breaking new ground sounds like $$$$ to me. If I could use one of those engines, I'd need it to make ~150 hp/L, which is where the modern engines seem to fall on the hp to weight index for PCA club racing. Base Macan motors are in the 300+ hp stock with plenty of torque, the S model is 400+ for hp and torque...no need for different cams! No biggie for me, I'll never have a race car so classification is no big deal (IMG:style_emoticons/default/smile.gif) |
Andyrew |
Oct 19 2016, 11:57 AM
He needs to be in the 1.8 to 2.0L range to run a turbo.
If he went water cooled he could run a vw 2.0L block from a 924. Im not sure if a better designed DOHC head would fit on that block but that would be a killer setup and let you make a ton of potential power. |
stownsen914 |
Oct 19 2016, 12:10 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
He needs to be in the 1.8 to 2.0L range to run a turbo. If he went water cooled he could run a vw 2.0L block from a 924. Im not sure if a better designed DOHC head would fit on that block but that would be a killer setup and let you make a ton of potential power. Interesting thought on swapping heads. PCA rules DO allow switching heads. Only the block has to be Porsche (or T4 or Audi/924). I'm probably showing my ignorance of 4 bangers here, but I wonder if a T1 head be massaged to fit on a T4 engine ... |
ThePaintedMan |
Oct 19 2016, 12:47 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Well if you insist on the Type 4 route, it would probably be easiest to go to Wasserboxer heads then. No way the Type 1 heads would ever fit - dimensions are way different. With the WBX heads you could actually make that thing live, sort of like a 4-cylinder 962 engine... (IMG:style_emoticons/default/idea.gif)
HAM Inc |
Oct 19 2016, 01:07 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
If you want to go T4 and can swap to any head, find some Engine Plus heads. They were most popular in Europe.
As for T1 heads, like I said before; where there's a wallet there's a way. Because of the wider bore center of the T4 you'd want to start with a set of 4 individual heads, like the scats. They would then need major mods to work with the T4 bolt pattern and lifter spacing. Bring a big pile of $$ and a shovel. |
Andyrew |
Oct 19 2016, 02:01 PM
Well if you insist on the Type 4 route, it would probably be easiest to go to Wasserboxer heads then. No way the Type 1 heads would ever fit - dimensions are way different. With the WBX heads you could actually make that thing live, sort of like a 4-cylinder 962 engine... (IMG:style_emoticons/default/idea.gif) I like the wasserboxer head idea. Run enough radiator and you can keep the damn thing cool for racing. You'll be generating a lot of heat with a turbo and really longevity is the key to racing. I dont think you should be shoveling into R+D on anything... Off the shelf parts and standard machining is the key IMHO. |
Mueller |
Oct 19 2016, 02:35 PM
Still going to be some work due to the passages that go to and from the block.
Some pictures of someone converting an air cooled cylinder to watercooled (might be oil cooled from another post) http://www.thesamba.com/vw/forum/viewtopic.php?t=584970 |
HAM Inc |
Oct 19 2016, 02:44 PM
Hate to spoil the Wasser fun, but... check the bore center. IIRC it's closer to the T1, which is waaay off from the T4. Not to mention the lifter spacing is off.
It will definitely not be an off the shelf deal. Nowhere near plug and play, even if the exhaust ports can be opened enough (and I don't think they can, but could be wrong) to support a 80+% ex/in flow ratio where intakes are moving in the ballpark of 180-200cfm at .5 lift, which I suspect you'll require for 175hp/l IMO, you need to keep looking. Len |
Mueller |
Oct 19 2016, 03:03 PM
Hate to spoil the Wasser fun, but... check the bore center. IIRC it's closer to the T1, which is waaay off from the T4. Not to mention the lifter spacing is off. It will definitely not be an off the shelf deal. Nowhere near plug and play, even if the exhaust ports can be opened enough (and I don't think they can, but could be wrong) to support a 80+% ex/in flow ratio where intakes are moving in the ballpark of 180-200cfm at .5 lift, which I suspect you'll require for 175hp/l IMO, you need to keep looking. Len Bummer, reality always getting in the way.... I figured it was too good to be true, I did find someone running those heads on a type I... http://www.shoptalkforums.com/viewtopic.ph...37&t=141797 |
ChrisFoley |
Oct 19 2016, 03:04 PM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I used to have pictures of a SCCA GT3 914 engine that was a T4 with watercooled heads.
Someone welded jackets onto a pair of OE heads. |
HAM Inc |
Oct 19 2016, 03:13 PM
I used to have pictures of a SCCA GT3 914 engine that was a T4 with watercooled heads. Someone welded jackets onto a pair of OE heads. That would be a hell of a lot easier than adapting something from another engine. But it too would not be for the faint of wallet, unless one could do the work themselves. |
Jetsetsurfshop |
Oct 19 2016, 03:29 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
If you want to go T4 and can swap to any head, find some Engine Plus heads. They were most popular in Europe. As for T1 heads, like I said before; where there's a wallet there's a way. Because of the wider bore center of the T4 you'd want to start with a set of 4 individual heads, like the scats. They would then need major mods to work with the T4 bolt pattern and lifter spacing. Bring a big pile of $$ and a shovel. Think the Engine Plus heads will handle the heat? Did they move the exhaust port to the ends? Were they quality casting? I'm full of questions. (IMG:style_emoticons/default/bye1.gif) |
Mueller |
Oct 19 2016, 03:52 PM
If you want to go T4 and can swap to any head, find some Engine Plus heads. They were most popular in Europe. As for T1 heads, like I said before; where there's a wallet there's a way. Because of the wider bore center of the T4 you'd want to start with a set of 4 individual heads, like the scats. They would then need major mods to work with the T4 bolt pattern and lifter spacing. Bring a big pile of $$ and a shovel. Think the Engine Plus heads will handle the heat? Did they move the exhaust port to the ends? Were they quality casting? I'm full of questions. (IMG:style_emoticons/default/bye1.gif) If I read that one post I added correctly, it looks like no longer available new. Yes to the Type I exhaust ports. |
Andyrew |
Oct 19 2016, 03:56 PM
For the cost of a tig welder and some aluminum that would be a killer way of doing it.
HAM Inc |
Oct 19 2016, 04:22 PM
For the cost of a tig welder and some aluminum and a skillful weldor with a few years of experience that would be a killer way of doing it. Fixed that for you. (IMG:style_emoticons/default/beer.gif) |
Andyrew |
Oct 19 2016, 04:23 PM
For the cost of a tig welder and some aluminum and a skillful weldor with a few years of experience that would be a killer way of doing it. Fixed that for you. (IMG:style_emoticons/default/beer.gif) Meh its just aluminum, how much different can it be than steel (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/lol-2.gif) |
Mueller |
Oct 19 2016, 04:55 PM
TIG welder (AC/DC) = check
Machine shop = check Certified welder (expired) = check (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/MDB2.gif) |
HAM Inc |
Oct 19 2016, 04:59 PM
TIG welder (AC/DC) = check Machine shop = check Certified welder (expired) = check (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/MDB2.gif) This is the sort of project that I think would be cool for a highly skilled, well equipped enthusiast. Someone with the know how, the time, and finances to give it a go. You should give this a try. |
stownsen914 |
Oct 20 2016, 05:13 AM
I understand that the water jacket idea had been done before on a 911 too. Might have been Grady Clay? Read about it on the Pelican forum at one point.
And, well, I've done a good but of MIG, but no TIG, so that might be a bit ambitious for me. Very cool idea though (pun intended!) |
Randal |
Oct 20 2016, 12:22 PM
TIG welder (AC/DC) = check Machine shop = check Certified welder (expired) = check (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/MDB2.gif) This is the sort of project that I think would be cool for a highly skilled, well equipped enthusiast. Someone with the know how, the time, and finances to give it a go. You should give this a try. How much time do you estimate that job would take you in hours Len? Just like to have a baseline of time and or related cost. Thanks. |
Lo-Fi Version | Time is now: 29th April 2024 - 12:10 PM |
