did I overheat tires?, rubber migration on A7 |
mskala |
Oct 13 2016, 06:42 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
This is what both my rears looked like after last weekend auto-x. It wasn't
even hot outside. Is this an indicator of anything particular I'm doing wrong? About the only abnormal thing on the course was a long 180 that was not quite a hairpin but I had the gas pedal to the floor for the whole last half of it. Basically with a 2.3 and limited slip and my setup, no possible way to spin with foot on the floor. |
mskala |
Oct 26 2016, 12:39 PM
Yeah, I actually found that the 'adhesive remover' blade for the vibrating saw tool
thing gets the excess rubber off pretty easily. So, my tires aren't blue or ridiculously worn after 5 events (8-9 runs avg). However, at the last event we did 6 in the morning and 6 again in the afternoon. By the 5th and 6th runs the car felt really sloppy and even though I was driving a better line it was slower. Not 'overheating' but out of the good grip temp range of the 'A' compound. So, IMO the A7 is inferior to the A6 where I never noticed this. Either I should go to the R7 or find something else maybe. Anybody looking for a good deal on used 205-45-16? |
ChrisFoley |
Oct 27 2016, 01:20 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
6freak |
Oct 27 2016, 03:20 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
By the 5th and 6th runs the car felt really sloppy and even though I was driving a better line it was slower. Not 'overheating' but out of the good grip temp range of the 'A' compound. Tire pressure. yep building heat/pressure fast with AX tires and not checking pressures after every run will make basketballs outta them! even on a cool day.... |
mskala |
Oct 27 2016, 04:20 PM
I check pressure after every run and reduce back to my 'target'.
Lo-Fi Version | Time is now: 17th May 2024 - 04:48 AM |
