did I overheat tires?, rubber migration on A7 |
mskala |
Oct 13 2016, 06:42 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
This is what both my rears looked like after last weekend auto-x. It wasn't
even hot outside. Is this an indicator of anything particular I'm doing wrong? About the only abnormal thing on the course was a long 180 that was not quite a hairpin but I had the gas pedal to the floor for the whole last half of it. Basically with a 2.3 and limited slip and my setup, no possible way to spin with foot on the floor. |
mskala |
Oct 26 2016, 12:39 PM
Yeah, I actually found that the 'adhesive remover' blade for the vibrating saw tool
thing gets the excess rubber off pretty easily. So, my tires aren't blue or ridiculously worn after 5 events (8-9 runs avg). However, at the last event we did 6 in the morning and 6 again in the afternoon. By the 5th and 6th runs the car felt really sloppy and even though I was driving a better line it was slower. Not 'overheating' but out of the good grip temp range of the 'A' compound. So, IMO the A7 is inferior to the A6 where I never noticed this. Either I should go to the R7 or find something else maybe. Anybody looking for a good deal on used 205-45-16? |
ChrisFoley |
Oct 27 2016, 01:20 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
6freak |
Oct 27 2016, 03:20 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
By the 5th and 6th runs the car felt really sloppy and even though I was driving a better line it was slower. Not 'overheating' but out of the good grip temp range of the 'A' compound. Tire pressure. yep building heat/pressure fast with AX tires and not checking pressures after every run will make basketballs outta them! even on a cool day.... |
mskala |
Oct 27 2016, 04:20 PM
I check pressure after every run and reduce back to my 'target'.
6freak |
Oct 27 2016, 09:06 PM
I check pressure after every run and reduce back to my 'target'. By the 5th and 6th runs the car felt really sloppy and even though I was driving a better line it was slower. Not 'overheating' but out of the good grip temp range of the 'A' compound. Tire pressure. yep building heat/pressure fast with AX tires and not checking pressures after every run will make basketballs outta them! even on a cool day.... OK check and check what are they set at and whats normal ambient temp and how long are your course`s its all i can think might do what your describing those are very very good DOT AX tires and they all (Slicks)gather marbles when there hot with the Kumho 205 -50-15 tire i run 22-24 in front 24 26 in back, colder days (PNW) its more to the lower PSI.but i like my car a little on the loose side and i can feel the car going away with lower PSIs ..our course`s are very tight in the 56 second time range and i like to slide the back end around the tight turns 0 over heat just normal build up...another 914 guy here runs same tires as you (slight flared fenders) and ive heard him say up to 32 PSI WOW! I would run those probable not at that PSI but they dont fit under my car not even the 205 50 15`s too wide .....so IMO its not the tires, its YOU (IMG:style_emoticons/default/biggrin.gif) getting faster and overcome grip factor in the way your driving! dont upset the car so much..Smooth but a little bit loose in the corners is good if you can keep the ass end hanging out there a foot or so and drive through it with the pedal to the metal Smooth = fast even if your cars not going strait and you have to counter a bit...yes strait with no slide is fastest but when you can help but slide because of your speed you then must become smooth to go faster....ask me how i know (IMG:style_emoticons/default/first.gif) I love those things Play with the PSI`s.. have fun and drive the wheels off that bitch (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 07:40 PM |
