FS: Mahle 94mm pistons and 94 mm cylinders, ********Sale. Pending*********£££ |
jim_hoyland |
Oct 16 2016, 01:33 PM
Get that VIN ? Group: Members Posts: 9,297 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I just had a top end rebuild and replaced heads, Pistons and Cylinders with 96mm. These were on my low-milage 914 for about 10 years. I cleaned up the Pistons a bit but haven't got to the cylinders.
$150.00 And, two 1.8 cylinder heads, no cracks apparent, but #3 spark plug hole needs to be retapped $100 They were mounted on my 1.8 L-Jet motor Attached image(s) |
jim_hoyland |
Oct 16 2016, 02:07 PM
I'll be attending Bruce's swapmeet next Sunday in Riverside, and can bring these. I'll only be there early in the am though.......
914_teener |
Oct 16 2016, 04:51 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Jim,
Changed my mind. I'll take them. See you next weekend. Rob |
jim_hoyland |
Oct 16 2016, 06:11 PM
914_teener |
Oct 16 2016, 06:58 PM
Heads if you will do that.
Rob |
914_teener |
Oct 16 2016, 07:04 PM
Lo-Fi Version | Time is now: 16th May 2024 - 07:24 PM |
