BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time... |
tygaboy |
Oct 17 2016, 10:56 AM
914 Guru Group: Members Posts: 5,265 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Hi World!
Let the games begin! (IMG:style_emoticons/default/piratenanner.gif) As the title says, it's a '75 that's getting an LS3 (Cracker's "old" motor - thanks Tony!) and Boxster 6 speed. Also planned is zippidy doo-dah 911 front suspension with Boxster calipers all around. The rear suspension is getting 911 ebrakes, Tangerine Racing raised pickups and shock towers. I have plans to stiffen the chassis with a partial cage. Doesn't that sound like a great plan? I think so, too! BACKGROUND: I got this as a roller that was purported to be "dry and accident free". And it was! Except for all the rust and the place where it was hit. Yeah, yeah... But it's all good. The seller and I worked everything out. (IMG:style_emoticons/default/beerchug.gif) But our little 914s are full of surprises and isn't that half the fun? So, first up is rust repair time! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) Let's begin with some pics of what I started with. Wish me luck! Wait, forget the luck, wish me SKILL!!! Attached image(s) |
Cracker |
Oct 23 2016, 03:39 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Chris - You don't need to have your bar that high - consider what I designed for you below (and if followed) - never look back.
The center support is important and I would not eliminate it from the design. The gussets at each end upright are absolutely necessary and should be implemented. Call me if you need to discuss. I too will be re-configuring my cage in the next year or so - converting it to a more "hot rod" style like your car. I won't go any higher than the 4.5" (and probably even lower) from top of rocker to top of bar I've illustrated below when I do it (JMO). Keep up the good work. Tony |
tygaboy |
Oct 23 2016, 05:26 PM
Chris - You don't need to have your bar that high - consider what I designed for you below (and if followed) - never look back. The center support is important and I would not eliminate it from the design. The gussets at each end upright are absolutely necessary and should be implemented. Call me if you need to discuss. I too will be re-configuring my cage in the next year or so - converting it to a more "hot rod" style like your car. I won't go any higher than the 4.5" (and probably even lower) from top of rocker to top of bar I've illustrated below when I do it (JMO). Keep up the good work. Tony Now that's what I call "Community Support"! Personalized, no less... Thanks Tony! And I agree, the height needs to come down. Mostly because at 5", you can't open the door from the inside - the bar interferes with the handle. So that's going to determine the final height. Looks like about 4" to the top of the bar. And my race car buddy did come by. I believe I now have a final design for the entire cage structure, floor and cross bracing and a cool tunnel! More soon. |
Lo-Fi Version | Time is now: 18th April 2024 - 06:47 AM |
