> BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time...
tygaboy
post Oct 17 2016, 10:56 AM
Hi World!
Let the games begin! (IMG:style_emoticons/default/piratenanner.gif)
As the title says, it's a '75 that's getting an LS3 (Cracker's "old" motor - thanks Tony!) and Boxster 6 speed.
Also planned is zippidy doo-dah 911 front suspension with Boxster calipers all around. The rear suspension is getting 911 ebrakes, Tangerine Racing raised pickups and shock towers.
I have plans to stiffen the chassis with a partial cage.
Doesn't that sound like a great plan? I think so, too!
BACKGROUND:
I got this as a roller that was purported to be "dry and accident free". And it was!
Except for all the rust and the place where it was hit. Yeah, yeah... But it's all good. The seller and I worked everything out. (IMG:style_emoticons/default/beerchug.gif)
But our little 914s are full of surprises and isn't that half the fun? So, first up is rust repair time! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif)
Let's begin with some pics of what I started with. Wish me luck! Wait, forget the luck, wish me SKILL!!!
tygaboy
post Nov 27 2016, 06:23 PM
My optimism regarding how much I'd get done this weekend was, well, optimistic.
I was only able to get the stiffeners welded in and the welds ground. Took WAY longer than I expected.
I did get the lower fire wall support pads fit and welded in and the upper brace fit and ready for welding.
CHANGES OF PLAN:
1. I'm tossing those motor mount plates in favor of modifying the Renegade motor mount. It has an offset at the ends to allow for the use of the stock engine mount location while pushing the engine back to clear all the stock sheet metal.
I've decided to modify the ends of the mount to move the mounting points to be in line with the mount. That'll get me a bit more than an inch and I think it's a tidier modification.
2. I'm also tossing the existing front hoop in favor of a taller one that will sit in a different location. It'll be way easier to show pics than to explain it. I hope to get the new hoop bent up this week.
tygaboy   BUILD-OFF CHALLENGE: Tygaboy's '75 LS3   Oct 17 2016, 10:56 AM
tygaboy   Hey, looks pretty good! Let's have a look ...   Oct 17 2016, 10:58 AM
tygaboy   How about the hell hole? Hmmm.   Oct 17 2016, 11:00 AM
tygaboy   The outer longs? Pretty nice! No problem! ...   Oct 17 2016, 11:07 AM
tygaboy   Forgot the pic of the outer longs...   Oct 17 2016, 11:08 AM
tygaboy   A real contributing factor to the rust issue was f...   Oct 17 2016, 11:11 AM
tygaboy   So... NOW we'll let the games begin. And I wan...   Oct 17 2016, 11:26 AM
Cracker   Good "skill" Chris...do that motor proud...   Oct 17 2016, 12:12 PM
tygaboy   Good "skill" Chris...do that motor prou...   Oct 17 2016, 12:32 PM
Mueller   Whoa, that is going to be a little bit of work...   Oct 17 2016, 12:55 PM
tygaboy   In planning the fabrication of the sleeves needed ...   Oct 17 2016, 01:00 PM
tygaboy   I sliced the longitudinal repair section out of my...   Oct 17 2016, 01:11 PM
Racer Chris   I'm using Tangerine Racing's door brace ...   Oct 17 2016, 01:25 PM
tygaboy   [quote name='tygaboy' post='2412396' date='Oct 17...   Oct 17 2016, 01:57 PM
Racer Chris   ... Here's my super high-tech design. No doub...   Oct 17 2016, 02:16 PM
tygaboy   Hell hole/long repair welding nearly completed...   Oct 17 2016, 02:01 PM
tygaboy   My paranoia paid off and another Tangerine product...   Oct 17 2016, 02:10 PM
tygaboy   CHASSIS STIFFENING: Version 1 LS3 = I need to sti...   Oct 20 2016, 11:27 AM
tygaboy   CHASSIS STIFFENING:Version 1 From a design perspe...   Oct 20 2016, 11:35 AM
tygaboy   CHASSIS STIFFENING: Version II - Change of Plan A...   Oct 20 2016, 11:51 AM
worn   That said, I also wanted to hide as much of this...   Oct 20 2016, 01:09 PM
stevegm   Interesting idea. It should provide some stiffness...   Oct 20 2016, 12:15 PM
Cairo94507   Now that is a very cool way to stiffen the car and...   Oct 20 2016, 12:42 PM
Cracker   Very nice Chris...have it running at WCR! :sh...   Oct 20 2016, 12:49 PM
914forme   Very nice bar tuck. If your not planning on runni...   Oct 23 2016, 09:48 AM
tygaboy   Very nice bar tuck. If your not planning on runn...   Oct 23 2016, 01:25 PM
tygaboy   CHASSIS STIFFENING: Front Hoop/Door Bars In keepi...   Oct 23 2016, 01:42 PM
tygaboy   CHASSIS STIFFENING: Con'd Next, I started on ...   Oct 23 2016, 01:51 PM
Rand   I don't think you need three verts. My choice ...   Oct 23 2016, 02:00 PM
Cracker   Chris - You don't need to have your bar that h...   Oct 23 2016, 03:39 PM
tygaboy   Chris - You don't need to have your bar that ...   Oct 23 2016, 05:26 PM
Rand   Curious what your thoughts are on simply running...   Oct 28 2016, 06:17 PM
tygaboy   Curious what your thoughts are on simply runnin...   Oct 28 2016, 06:21 PM
Rand   I'm pretty sure that angle would make it toug...   Oct 28 2016, 06:33 PM
tygaboy   [quote name='tygaboy' post='2417024' date='Oct 28...   Oct 28 2016, 08:12 PM
mgp4591   [quote name='tygaboy' post='2417024' date='Oct 28...   Nov 5 2016, 03:31 AM
tygaboy   Oh boy. oh boy... is this going to be a full weeke...   Oct 28 2016, 05:58 PM
Mueller   I'd throw a seat in there 1st and test how muc...   Oct 28 2016, 06:07 PM
tygaboy   I'd throw a seat in there 1st and test how mu...   Oct 28 2016, 06:22 PM
Mueller   I'd throw a seat in there 1st and test how m...   Oct 28 2016, 07:17 PM
Dion   Fantastic fabrication. Way to go Chris. I'm ...   Oct 28 2016, 06:56 PM
Cracker   Something else to consider when designing your str...   Oct 28 2016, 08:37 PM
tygaboy   CHASSIS STIFFENING: Inner Longs Got started on th...   Oct 29 2016, 10:01 AM
Mueller   CHASSIS STIFFENING: Inner Longs Got started on t...   Oct 29 2016, 10:05 AM
tygaboy   Details, details... trim to fit - even the little ...   Oct 29 2016, 10:04 AM
tygaboy   Fitting the left side... This went way faster as I...   Oct 29 2016, 06:13 PM
Rand   Nice. You don't need a bunch of tubage. This a...   Oct 29 2016, 06:17 PM
tygaboy   Nice. You don't need a bunch of tubage. This ...   Oct 29 2016, 06:24 PM
Rand   Nice. You don't need a bunch of tubage. This...   Oct 29 2016, 06:35 PM
tygaboy   Another. And if you need to make large holes for t...   Oct 29 2016, 06:19 PM
Cracker   Your picture reminds me of a Fred Flintstone mobil...   Oct 29 2016, 06:47 PM
tygaboy   Artsy shot of the day. I just love the smooth, cle...   Oct 29 2016, 06:20 PM
tygaboy   CHASSIS STIFFENING: Lower Firewall Today's re...   Oct 30 2016, 09:53 AM
tygaboy   Then it's roll, check, roll, check. Manual rol...   Oct 30 2016, 09:55 AM
tygaboy   Looks good to me!   Oct 30 2016, 09:56 AM
tygaboy   I'm not so confident that I trust my measureme...   Oct 30 2016, 03:30 PM
tygaboy   In the pics above, the rear floor is just held in ...   Oct 30 2016, 03:36 PM
Cracker   Chris, I like it. One word of caution; however, d...   Oct 30 2016, 05:47 PM
tygaboy   Suspension porn! Got my trailing arms back fro...   Oct 30 2016, 06:37 PM
Cracker   Damn right those are slick...Foley does excellent ...   Oct 30 2016, 06:47 PM
914forme   Oh wow our builds are very close, I like what your...   Oct 30 2016, 07:55 PM
1stworks   Following. Thanks for sharing.   Oct 31 2016, 05:52 PM
Curbandgutter   Wow the build is looking great. I really liked yo...   Nov 2 2016, 05:08 PM
tygaboy   Engine & Trans: Mock Up November activities c...   Nov 4 2016, 05:22 PM
tygaboy   As I'm looking at this wild set up, I leaned u...   Nov 4 2016, 05:27 PM
914forme   All that tooling in your shop I am just :drooley:...   Nov 5 2016, 09:37 AM
tygaboy   All that tooling in your shop I am just :drooley...   Nov 5 2016, 09:56 AM
tygaboy   It was a frustrating weekend in that I didn't ...   Nov 6 2016, 06:02 PM
tygaboy   So the only progress to report for this weekend is...   Nov 6 2016, 06:05 PM
tygaboy   And after all this hard work, I'm adding a lit...   Nov 6 2016, 06:10 PM
JmuRiz   Amazing how compact an LS motor is!   Nov 6 2016, 06:21 PM
Krieger   Nice work Chris! You are making amazing progr...   Nov 6 2016, 07:36 PM
Cracker   Something else that just came to mind Chris...if y...   Nov 6 2016, 07:40 PM
tygaboy   Something else that just came to mind Chris...if ...   Nov 6 2016, 07:49 PM
tygaboy   So... the good/bad news is that this week I had my...   Nov 12 2016, 05:26 PM
tygaboy   I have a bit of 50" wide, 2x2 twill weave lef...   Nov 12 2016, 05:29 PM
tygaboy   A little mold release wax and PVA, then 2 layers o...   Nov 12 2016, 05:32 PM
tygaboy   And before you ask, yes, these covers are purely e...   Nov 13 2016, 09:23 AM
Cracker   Sweet, Chris...I can certify that you won't n...   Nov 13 2016, 09:29 AM
tygaboy   A couple of pics to give you the idea. I may have ...   Nov 13 2016, 09:36 AM
tygaboy   Well this was a "long" weekend! :lo...   Nov 13 2016, 03:47 PM
Dion   Fantastic work Chris.   Nov 13 2016, 04:05 PM
tygaboy   Fantastic work Chris. Thanks for the kind words...   Nov 13 2016, 04:59 PM
Curbandgutter   I like your carbon fiber idea. I just may shameles...   Nov 13 2016, 04:22 PM
tygaboy   I like your carbon fiber idea. I just may shamele...   Nov 13 2016, 04:57 PM
tygaboy   Before I install the long stiffeners, I need to cl...   Nov 18 2016, 06:30 PM
Rand   The ebrake void I get. But, don't bother weldi...   Nov 18 2016, 10:03 PM
tygaboy   The ebrake void I get. But, don't bother weld...   Nov 18 2016, 10:58 PM
Rand   The ebrake void I get. But, don't bother wel...   Nov 19 2016, 12:34 AM
tygaboy   Well, if Rand is concerned I'm overdoing it re...   Nov 19 2016, 01:59 PM
Rand   No concerns, lol. Just banter. :trophy:   Nov 19 2016, 02:02 PM
tygaboy   Major milestone! Got the engine and trans mock...   Nov 20 2016, 06:41 PM
Wew   Wow, well done Chris! :beer1:   Nov 20 2016, 08:20 PM
tygaboy   With the trans located, I could verify the shifter...   Nov 22 2016, 12:57 PM
tygaboy   OK, even I'm getting tired of pictures of this...   Nov 23 2016, 07:04 PM
tygaboy   A little holiday video of the H press in use bendi...   Nov 24 2016, 09:41 AM
tygaboy   Some of this fab work isn't the most exciting ...   Nov 25 2016, 07:30 PM
914forme   :agree: It is very easy to push your mounts forwar...   Nov 27 2016, 05:59 PM
tygaboy   :agree: It is very easy to push your mounts forwa...   Nov 27 2016, 06:25 PM
tygaboy   My optimism regarding how much I'd get done th...   Nov 27 2016, 06:23 PM
47 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 16th April 2024 - 02:17 AM
