billet intermediate plates, experiences? and specifically bearing question |
brant |
Oct 17 2016, 12:02 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
So I pulled the stack out of the race car this weekend for intermediate plate bearing inspection. Of the 4-5 tranny's I've lost racing over the last years... its always been the intermediate plate bearings that have failed.
I realize this may be due to a combination of factors -old bearings -flex in the intermediate plates, causing the bearing failures So this weekend, I had good news... no impending bearing failure that I could visually detect still I think its time to upgrade to a billet intermediate plate before too long. 1) I'd love to know which brands of billet intermediate plates people are using? 2) I'd really love to know, if anyone makes a billet plate that takes an aftermarket (much more affordable) bearing. I see PMS has the factory Porsche bearings at $400+, but wouldn't it make sense to produce a billet intermediate plate that took a more cost effective non Porsche bearing? maybe its out there, I haven't researched much yet.... thought I'd start here with the brain trust. tia brant |
Matt Romanowski |
Oct 31 2016, 10:26 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
We used one from California Motorsports. It will be for sale this winter with a bunch of our 901 stuff. We killed 4th gear for the last time.....
We have the intermediate plate, side plate, bearing retainer, Tangerine shifter, and a Rennshifter. |
brant |
Nov 1 2016, 09:17 AM
We used one from California Motorsports. It will be for sale this winter with a bunch of our 901 stuff. We killed 4th gear for the last time..... We have the intermediate plate, side plate, bearing retainer, Tangerine shifter, and a Rennshifter. Matt, in all of the transmissions you have been through... do all of the intermediate plates run a Porsche stock bearing ? does the California Motorsports? I keep having the bearing fail in the intermediate plate wondered if any of the billet plates had gone to an aftermarket bearing that might be: 1)higher quality 2)not $400/more affordable (its still only a bearing) |
Matt Romanowski |
Nov 7 2016, 10:26 PM
Matt, in all of the transmissions you have been through... do all of the intermediate plates run a Porsche stock bearing ? does the California Motorsports? I keep having the bearing fail in the intermediate plate wondered if any of the billet plates had gone to an aftermarket bearing that might be: 1)higher quality 2)not $400/more affordable (its still only a bearing) They have all taken stock bearings. I haven't had the bearings fail. It's usually part of the ring and pinion that starts going. If we miss the start and it chunks, it will hurt the bearings. Interesting that you have had bearing failures. I would suggest you have the bearings, races, gears, ring, pinion, and anything else you can send cryo treated and REM polished. I would also suggest Amsoil gear lube. I think it was as good as the really expensive stuff. |
brant |
Nov 7 2016, 11:39 PM
Matt, in all of the transmissions you have been through... do all of the intermediate plates run a Porsche stock bearing ? does the California Motorsports? I keep having the bearing fail in the intermediate plate wondered if any of the billet plates had gone to an aftermarket bearing that might be: 1)higher quality 2)not $400/more affordable (its still only a bearing) They have all taken stock bearings. I haven't had the bearings fail. It's usually part of the ring and pinion that starts going. If we miss the start and it chunks, it will hurt the bearings. Interesting that you have had bearing failures. I would suggest you have the bearings, races, gears, ring, pinion, and anything else you can send cryo treated and REM polished. I would also suggest Amsoil gear lube. I think it was as good as the really expensive stuff. I like the cryogenic idea. I don't have the torque to tear out the ring/pinion. But my rpm still creates a lot of heat and the bearings seem to be the first thing for me |
jd74914 |
Nov 8 2016, 10:35 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I would suggest you have the bearings, races, gears, ring, pinion, and anything else you can send cryo treated and REM polished. I would also suggest Amsoil gear lube. I think it was as good as the really expensive stuff. I like the cryogenic idea. I don't have the torque to tear out the ring/pinion. But my rpm still creates a lot of heat and the bearings seem to be the first thing for me (IMG:style_emoticons/default/agree.gif) I have no 914 tranny experience, but we kept breaking 2nd gear teeth on a GSXR motor in car and ended up cryoing it with great success. We used to go through at least one second gear pair per season and the cryo'd set has lasted 4 years so far. (IMG:style_emoticons/default/smile.gif) Edit: These guys did the gears and they were very inexpensive and quite fast. http://hekimianracing.com/ |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:27 AM |
