Quickie 2.0 Rebuild |
McMark |
Oct 17 2016, 05:21 PM
One of my winter tasks is to build a stock 2.0 with my MicroSquirt fuel injection that I can install in my car and get it dyno tuned. That's been the missing piece of my MicroSquirt setup for the last few years.
Since there isn't much demand for a stock 2.0, I just plan on doing the minimum to build a solid motor. I plan on having the valves reground, cylinder surfaces machined and reringing the pistons. Regrinding the cam and rebuilding the rods and all new bearings as well. This should give me a motor that will last through the testing, and be worth something when I'm done to pass on to a new owner at a nice price. This thread does not represent my standard procedures for rebuilding engines. This is a special case and special circumstances. For those of you on a budget, but looking to refresh their motor should appreciate this writeup. Starting off with a core engine. The previous owner mentioned this engine had a 'knock', so I'll be on the lookout for what might have caused that. This is a 'GC' code engine with air injection ports in the heads. Attached image(s) |
McMark |
Oct 2 2017, 08:19 PM
Everyone's got their ways, that's part of what makes this all interesting.
I will address the 'loose' key. I'm talking about a key that slides smoothly through the keyway. Not loose. Not dropping out on it's own. Just smooth even tension. The goal is just slightly less tension than tap-it-with-a-hammer tight. Fine sandpaper and slow methodical process with frequent checks are they way. Like taking 5m to true up one key. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:45 PM |
