Surging and Unsettled Idel after MPS Rebuild, '74 2.0L D-Jet |
914four |
Oct 17 2016, 07:36 PM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
Running down a bucking issue and found my MPS to be leaking. After rebuilding the MPS and verifying a good seal, everything went back together okay. When I started the car, the engine surged up and down and would not idle.
The electrical connector socket on the MPS does not appear to be keyed and using the diagram below from Clay's D-Jet troubleshooting guide it seems I may have plugged in the MPS wire incorrectly. I ohmed the wires from the ECU connector to the MPS socket and made sure the wires are in the order shown in the diagram. The wires look to be looping back from terminal 7 to 15 and 8 to 10 so that the socket could be plugged in either way and work correctly. Could plugging in the MPS wires incorrectly have damaged the ECU? If not, what should I be looking for that would cause the surging and lack of idle? |
cary |
Apr 3 2017, 07:53 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I built one with a new paint can. Worked great to find a vacuum leak on a Ford 4.0. I got the design off You Tube. Haven't used it on a 914 yet, but plan to when the need arises.
Lo-Fi Version | Time is now: 25th May 2024 - 05:54 AM |
