Selling the teener.. maybe? |
Chris H. |
Oct 18 2016, 06:19 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
... Well, that's the deal breaker for me (IMG:style_emoticons/default/laugh.gif) Stuff todo: Fresh air blower doesn't work Fog lights disconnected GLWTS, sharp looking car ... (IMG:style_emoticons/default/lol-2.gif) I was gonna say that too. That could be $25 easy. Maybe even $50! NICE car. Very nice. |
Cracker |
Oct 18 2016, 06:21 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Mr. Raby just pulled the same stunt not long ago...low, real low.
Tony Drive it more! Otherwise, here's where you should post: http://www.914world.com/bbs2/index.php?showforum=20 |
Cracker |
Oct 18 2016, 06:22 PM
Sounds like you've made up your mind...or it has always been made.
Tony Thanks guys - and great to hear from you Valy, glad you're still at the 914! I'd really have to dig through 30 years of records, but off the top of my head: 1973 914-6 2.7L Conversion Original California car, records going back to the early 80s. Conversion with mostly factory parts: 911SC front end with Bilstein inserts 914-6 stub axles 914-6 oil tank 914-6 heat exchangers (restored ~2 years ago) 6" genuine Fuchs wheels under slightly rolled fenders, 225-50 tires Engine: Otto's Rebuilt 2.7L with modified cams, machined case, etc. Receipts over $18,000+ back in the late 90s. Compression 175 across all 6, ~10,000 miles on it Added Carrera hydraulic tensionsers ~2 years ago 40IDA3C Weber Carbs Crane ignition Cosmetic: Non-stock metallic blue over original Olympic blue, from the late 90s. Repro polished stainless steel early-style bumpers, undrilled front bumper, new factory chromed fog grills New bumper tops Center reflector insert Fresh wiper arms and nuts Rust bubbles from bad windshield install, jackpoints should be ground off and replaced Hell hole is solid, as is the rest of the car Interior: Remanufactured dash top with ashtray delete German loop carpet in cinnamon Brown vinyl interior 9/10 Restored gauges + custom 4 gauge (oil, temp, volts, fuel) Momo prototipo steering wheel + offset spacer for more leg room 6" round speaker pods 8" fiberglass subwoofer in passenger footrest location Factory leather shift gaitor New aluminum door sills Lots of fresh gaskets and other details Others: Brakes & suspension gone through - replated & rebuilt rear calipers, rebuilt front calipers and new MC, Bilstein HD shocks + Ground Control coilovers Optima Redtop AGM battery Many many other small details I'm sure I've forgotten Stuff todo: Fresh air blower doesn't work Fog lights disconnected |
dem |
Oct 18 2016, 07:16 PM
Rusty Member Group: Members Posts: 147 Joined: 7-February 10 From: Cupertino, CA Member No.: 11,334 Region Association: Northern California |
All the nice words make me want to keep it! (IMG:style_emoticons/default/smile.gif)
2 years ago I did spend $9K fixing up most of the niggling stuff (new alternator, tensioners, restoring heat exchangers, oil leaks, etc etc) - but still didn't end up driving it much. Of course the same could be said of my motorcycle. I don't know.. I guess we'll know if I end up bumping this thread in a year! After owning 914s for 20 years, it would be weird to be without one in my garage! Final pic.. my original '74 Creamsicle in disguise, from 1995: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.haphazard.com-11334-1476839785.1.jpg) |
napasteve |
Oct 20 2016, 04:19 PM
914 driving winemaker Group: Members Posts: 501 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
Dem, would you share where you had your quad gauge made? Details?
EdwardBlume |
Oct 21 2016, 01:26 PM
I don't think holding on to it will cost you much.... then again, if the money in the bank will make you smile more.... (IMG:style_emoticons/default/dry.gif)
914z |
Oct 22 2017, 12:46 AM
Newbie Group: Members Posts: 35 Joined: 11-September 04 From: Los Angeles, CA Member No.: 2,737 |
Dem, would you share where you had your quad gauge made? Details? North Hollywood Speedometer can probably build one for you http://www.nhspeedometer.com/ |
Lo-Fi Version | Time is now: 11th May 2024 - 03:45 PM |
