6 Pages V < 1 2 3 4 5 > »
> Dads new car
mb911
post Jun 9 2018, 09:16 AM
Post #41
Here are some pictures of the car. Attached Image Attached ImageAttached ImageAttached Image[attachmentid=654
155]Attached Image
Rob-O
post Jun 9 2018, 10:13 PM
Post #42
Nice! At least he’s making progress, even if it’s slow going.
Nice to see some folks stepping up and donating some parts. Kevin is a good guy, he sent me an enormous box of parts awhile back. Mark is stand up, too.
Just from the photos I’ve seen I’ve got a few things I could send your way. I think I have a relay board cover and I know I definitely have a new front trunk seal. If you have a list send me a PM. I’ll gather what I have and get it to you. Just paying it forward...
porschetub
post Jun 10 2018, 12:40 AM
Post #43
Looks like a sound car,best to motor out as its a lot harder to free up otherwise.
Dump the oil and look for whitemetal and other bits you may find in the oil filter if you open it ,if that's ok the bottom end should be fine ,pull the motor and dose with a penetrant or what ever you want down the inlets...let it soak.
I will mention what I did with a seized T4 1800 only months ago,flywheel was off so I found some meaty HT bolts and fitted them in the flywheel ,had previously put kerosene down the intakes cause that's all I had,heated the barrels with a heat gun,rocked it back and forward with a bar and it turned after a couple of repeat attempts,haven't stripped it right down yet but one good thing is it appears to have no valve issues.
Good luck.
ClayPerrine
post Jun 10 2018, 06:10 AM
Post #44
I saw in the picutres that the seat belt interlock relay is still connected. This will cause a no crank issue. There is a solid yellow wire and a yellow with a red tracer wire connected to them. Pull them from the relay and splice them together. That should fix the no crank issue.
And if you need anything, let me know. I probably have enough spare parts in my garage to build another 914 if I had a tub.
Rob-O
post Jun 10 2018, 07:23 AM
Post #45
QUOTE(ClayPerrine @ Jun 10 2018, 04:10 AM) *
Just one???? I’d say several...
EdwardBlume
post Jun 10 2018, 07:59 AM
Post #46
QUOTE(ClayPerrine @ Jun 10 2018, 05:10 AM) *
+1
If you need anything that I have I'll send it. Great to see Dad in action...
mb911
post Jun 10 2018, 11:42 AM
Post #47
Thanks everyone.. I will have dad make a list. I have been giving him any spares that I have and I know he would appreciate any help as he is on a very fixed income..
On his shortlist I know he wants to buy new ignition wires, cap, rotor for sure..
mb911
post Jun 11 2018, 02:21 PM
Post #48
Dad just sent me a list.. I messed up and gave away an engine lid. Oh well..
The List
and pan
Antenna fender mount
Outside door handles and seals
Trunk gasket
Steering wheel and hub cover
Gas tank strap and rubber cushion passenger side
Driver's side mirror
Window handles
Front quarter windows with windowrails
Front side marker light assemblies
Hand brake- Handle assembly
Trunk latch assembly Distributor cap
Plug wires
Brake hoses
Rear brake pads
Inner door panels
Passenger window glass with mounting rail
Engine lid assembly
post Jun 11 2018, 02:40 PM
Post #49
914-6 GT in waiting
The List
and pan - ?
Antenna fender mount - probably
Trunk gasket
Steering wheel and hub cover - yes
Gas tank strap and rubber cushion passenger side - yes
Driver's side mirror - yes
Window handles- yes
Front quarter windows with windowrails - yes
Front side marker light assemblies - yes
Hand brake- Handle assembly - yes
Trunk latch assembly - yes
Distributor cap
Plug wires
Brake hoses
Rear brake pads
Inner door panels - yes, tan
Engine lid assembly- yes
mb911
post Jun 11 2018, 03:23 PM
Post #50
QUOTE(mepstein @ Jun 11 2018, 12:40 PM) *
The List
and pan - ?
Trunk gasket
Window handles- yes
Distributor cap
Plug wires
Brake hoses
Rear brake pads
Mark,
Clay is helping out with an engine lid., I found some door panels I will give him and 1 wart assembly , rear latch as well..
Making a smaller list. Yeah..
post Jun 11 2018, 03:36 PM
Post #51
914-6 GT in waiting
QUOTE(mb911 @ Jun 11 2018, 05:23 PM) *
The List
and pan - ?
Trunk gasket
Window handles- yes
Distributor cap
Plug wires
Brake hoses
Rear brake pads
Mark,
What’s the first thing on the list ?
“And pan”
mb911
post Jun 11 2018, 03:48 PM
Post #52
QUOTE(mepstein @ Jun 11 2018, 01:36 PM) *
The List
and pan - ?
Trunk gasket
Window handles- yes
Distributor cap
Plug wires
Brake hoses
Rear brake pads
Mark,
“And pan”
I am not sure it was in a text message from my step mom so not sure what that means.
914Sixer
post Jun 11 2018, 04:14 PM
Post #53
I have the rear brake pads, Need shipping info.
mb911
post Jun 11 2018, 04:22 PM
Post #54
QUOTE(914Sixer @ Jun 11 2018, 02:14 PM) *
Mark
Pm on way.. Thanks
Everyone thanks for the generosity..
EdwardBlume
post Jun 11 2018, 07:39 PM
Post #55
QUOTE(mepstein @ Jun 11 2018, 01:40 PM) *
The List
and pan - ?
Trunk gasket
Window handles- yes
Distributor cap
Plug wires
Brake hoses
Rear brake pads
I have (2) decent Right Side outer door handles that can be combined to make one good one, plus 2 new seal kits for the outer door handles.
Is the trunk gasket front or rear?
mb911
post Jun 11 2018, 08:47 PM
Post #56
QUOTE(Edward Blume @ Jun 11 2018, 05:39 PM) *
The List
and pan - ?
Trunk gasket
Window handles- yes
Distributor cap
Plug wires
Brake hoses
Rear brake pads
Rear.. I gave him a semi decent front one..
ClayPerrine
post Jun 12 2018, 08:34 AM
Post #57
A silver engine lid has been shipped. It is going slow boat via parcel post. Otherwise it was going to be $200.00 to ship due to it being oversized.
Tracking #9461210200830953140314
Hope it helps him out!
mb911
post Jun 12 2018, 09:39 AM
Post #58
QUOTE(ClayPerrine @ Jun 12 2018, 06:34 AM) *
Thank you and completely understand slow boat is fine.. My dad operates at this level anyway.
mb911
post Jun 12 2018, 03:21 PM
Post #59
Talked to dad today. He is excited and thankful for all the help.. He is a long time enthusiast. Over the years he had 3 356s, 2 912s, 2 914s, 1 924 turbo and countless British cars. Unfortunately he sold all of them before each became valuable except the last 356 which he was able to make some money on.. Not nearly enough for retirement after a divorce etc.
He is heading into the garage this afternoon to do some work.
914forme
post Jun 12 2018, 05:51 PM
Post #60
Side window with rail - tinted or clear?
I might have what he needs in the hoard, ahh I mean parts awaiting future projects located in my shop. (IMG:style_emoticons/default/beer.gif)
Presuming since it is a 74 nobody put an early door on that side. I probably have that one in the hoard (IMG:style_emoticons/default/headbang.gif) ahh valuable parts awaiting future projects pile.
Still working on the proper wording to make the parts hoarding seem like less of an issue and more of a planned future, yeah that was a smart thing todo sort of thing. (IMG:style_emoticons/default/av-943.gif)
- Lo-Fi Version Time is now: 16th April 2024 - 12:52 AM
