Most Embarrassing Cars Ever Built, by Otherwise Excellent Automakers |
siverson |
Oct 19 2016, 04:35 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Not sure if this has been posted, but I thought I'd share. The title is click bait, but is actually a fairly complementary write-up of the "weird-looking" 914.
http://www.roadandtrack.com/car-culture/g6...ilies/?slide=14 Porsche 914 Plenty of myths swirl around the 914, the most persistent of which is that the car was a repurposing of a concept penned by industrial designer Hans Gugelot. But the truth is Porsche's Heinrich Klie, designer of the iconic five-lug Fuchs wheel, did the majority of the aesthetic work on the machine. The rear suspension isn't shared with any other car, while the front is pulled from the 911. The five-speed transmission, though it may have VW emblems stamped on the case, is the same unit used in 1960s and early '70s 911s. Did we mention that Ferdinand Piëch was in charge of the 914 program, at the same time he was spearheading the development of the vaunted 917? In fact, aside from a corporate steering column used on the four-cylinder cars, some underdash wiring bits and pieces, and the Type 4 engine (which was reworked by none other than Hans Mezger in 2.0-liter guise), the 914 was much more Porsche than Volkswagen. It's certainly more Porsche than a Macan or a Cayenne, and at least as much a Porsche as a Panamera. And if you argue that it was built at Karmann, might we remind you that the Boxster and Cayman were constructed at Valmet in Finland? Is the 914 a black sheep? Yes. Have a gander at the thing. It iskinda weird-looking. Is it a Porsche? Also yes. Very much so. —Davey G. Johnson -Steve |
siverson |
Oct 21 2016, 02:12 PM
> In truth, the front suspension was designed for the 914 and then carried over to the 911
Really? Isn't the 914 front suspension remarkably similar to the early (1965) 911 suspension? -Steve |
gms |
Oct 27 2016, 08:43 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
> In truth, the front suspension was designed for the 914 and then carried over to the 911 Really? Isn't the 914 front suspension remarkably similar to the early (1965) 911 suspension? -Steve yup, that is why the 911 steering rack had a 914 part number into the '80s |
Lo-Fi Version | Time is now: 19th May 2024 - 04:19 AM |
