Rough cylinder walls, What can be the cause? |
HansJan |
Oct 19 2016, 09:28 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
Today the shop had taken the engine out of the car, just to replace the very stiff valve springs. When the heads came off we noticed that there are rough areas on the cylinder walls. Not everywhere, but at least two areas per cylinder. FYI: Cylinders are 103.8 mm (by AA). Pistons are also by AA. Markings on cam: CWC Valves Intake: 44.35 mm Valve Exhaust: 38 mm My question to the brain-trust is: What could be the cause for the rough areas? Some back ground info: This car supposed to have "Nickies" Cylinders and JE-Pistons. Obviously the (Craigslist) seller and I are no friends. After receiving it, I drove the car for less then 10 minutes before the car caught on fire. |
cwpeden |
Oct 22 2016, 11:16 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
From a machinists point of view, those look like resonance rings.
As the cylinders were machined they were ringing and that pattern can translate all through finishing. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:26 PM |
