Weber carb set up help, Jetting seemed to help but still slight popping/backfire |
North Coast Jim |
Oct 20 2016, 09:33 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Just finished a new 2 liter engine build with Webcam for carbs installed.
New Raby heads, Hoffman Eng, are used. New 44IDF Webers installed with cross bar linkage. Valve lash to spec and timing is spot on. Carbs are synched. Continue to hear a slight popping from only the pass side carb at partial throttle positions. Car starts and idles with plenty of power thru acceleration, but who knows I haven't driven one in over 25 years. It's a hoot to drive except for the Issue. Played with jetting to no avail. Any Carb guru's out there able to provide input to solve this dilemma. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/confused24.gif) |
SKL1 |
Oct 21 2016, 09:39 PM
Senior Member Group: Members Posts: 1,598 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Good info- some news tricks as I'm fighting the popping etc on deceleration primarily. We get the sh**ty alcohol infested gas in AZ over half the year so in goes the Marine Stabil to help fight that problem at least a little...
The Tangerine linkage from Chris does help some with adjustments though! |
Lo-Fi Version | Time is now: 9th May 2024 - 10:06 PM |
