#3 plug is black... |
yellow75 |
Oct 20 2016, 03:59 PM
Member Group: Members Posts: 88 Joined: 1-October 16 From: pittsburgh Member No.: 20,452 Region Association: None |
pulled the plugs on my new to me 75 1.8 with carbs today. 1,2,&4 look good grey in the center (3 electrode plugs) black around the sides. # 3 was totally black. it was idling rough so I pulled one plug wire at a time to see the difference it made. All but #3 made a difference. When I pulled #3 there was no difference at all. It has an electronic fired dizzy in it as well. Cap and rotor are new. What ya think?
zach914v8 |
Oct 21 2016, 06:01 AM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
A quick and simple test to see if your plug wires are bad is get a water spray bottle and mist the wires gently, no need to go over board. If you have a bad wire blowing fire, you'll find it quick.
If misting doesnt tell you anything, install a spark checker on both a know good cylinder wire and the bad one. Look at the difference. A good ignition system should blow big blue 20kv spark. Just hook the end of the wire from the spark plug to the tester. That clamp on the tester, ground it to the engine. The spark tester gap is ajustable, 20kv is like a 20mm gap. |
Lo-Fi Version | Time is now: 28th May 2024 - 09:16 AM |
