Carburetored type IV engine problem diagnosis., Engine idling problem. |
Keith914 |
Oct 21 2016, 07:00 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
Just completed very careful cleaning, installing, adjusting, balancing two Weber carbs on my recently rebuilt '72 1.7 type IV 914 engine upgraded to 2.4 L. Carbs are real Webers (Spain), and we're working well earlier. Balancing and setting idle at 1,100 rpm was done on cold engine - nice smooth idle and solid response to accelerator action. The carbs are 44's, idle jets are 55's, main jets are145's and the air jets are 200's. Sea level ambient condition.
Engine starts immediately and runs very well and continues to run very well above about 2,000 rpm. But once engine is approaching and then at normal operating temp - 190 F, it will not run smoothly below about 2,000 rpm, and at idle accelerator position, engine drops below 1,000 rpm and stumbles to stalling sometimes with pre ignition sounds as it stalls! Timing is set at 32 degrees at 3,000 rpm, and distributor is new with new Pertronix electronic unit, and no vacuum mechanism. Welcome any diagnosis suggestions. |
Valy |
Oct 21 2016, 09:00 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
You should adjust carbs when engine is warm, not cold.
Sounds like the mixture is too rich at idle. |
Keith914 |
Oct 21 2016, 09:11 PM
Lo-Fi Version | Time is now: 25th May 2024 - 07:26 PM |
