KONIG SEATS, Rail Slider Hardware |
yello914 |
Oct 21 2016, 10:19 PM
Member Group: Members Posts: 67 Joined: 18-May 05 From: Southern California Member No.: 4,099 Region Association: None |
Greetings!!
Is anyone using Konig seats? I am trying to install a new pair I bought a few years ago and cannot seem to get the original allen head bolts on.. They go in about a half turn and stop.. I don't want to strip/cross thread the holes and wonder if they require special hardware. Feedback would be greatly appreciated!! Cheers |
dangrouche |
Oct 21 2016, 11:19 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
they are nothing out of the ordinary. You need to chase those threads with some oil and maybe some "sacrificial screws" to get those threads opened up smoothly. They are not 100% perfectly aligned like OEM seats, so, you need to be patient and methodical in attaching the tracks. If alignment is off, then I would err on the side of enlarging the track holes, since tracks are readily plentiful. The harbor Freight tap and die set should help you get this project done. load the screw in a counterclockwise direction and listen for a click, this is a technique used when reattaching grip screws on a handgun. once you hear the click, the screw is seated on the first thread, then you proceed with turning the screw by hand and feel it loading into the hole. then chase it fully down the entire path of the threading.
yello914 |
Oct 22 2016, 02:38 AM
they are nothing out of the ordinary. You need to chase those threads with some oil and maybe some "sacrificial screws" to get those threads opened up smoothly. They are not 100% perfectly aligned like OEM seats, so, you need to be patient and methodical in attaching the tracks. If alignment is off, then I would err on the side of enlarging the track holes, since tracks are readily plentiful. The harbor Freight tap and die set should help you get this project done. load the screw in a counterclockwise direction and listen for a click, this is a technique used when reattaching grip screws on a handgun. once you hear the click, the screw is seated on the first thread, then you proceed with turning the screw by hand and feel it loading into the hole. then chase it fully down the entire path of the threading. Thank You for replying and providing detailed instructions!! |
Lo-Fi Version | Time is now: 18th May 2024 - 09:19 PM |
