What's the best way to store parts, Cosmoline spray? |
jsaum |
Oct 22 2016, 10:15 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I have two transmissions and a couple of spare motors that I want to break down so I can store them in the crawl space under my house. The wife says the garage needs to get cleaned up! It stays dry but there is a lot of moisture in the air what is the best way to keep the cases from corrosion? I was thinking cosmoline spray then putting the parts in heavy duty plastic bags and boxing them up. Is there something that's easier to clean up than cosmoline?
Jsaum |
N_Jay |
Oct 22 2016, 03:31 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
How long and how damp?
Protective spray (NOT WD40) and well wrapped (air tight) is probably good for most situations. Make sure the spray says on ALL machined surfaces. Long storage or very damp, I would use the soaked cloth as suggested. I don't think you need "Vacuum sealing" but would probably use packing shrink wrap over the bag to compress out some air and keep it from "Breathing". Also "assembled" is better than disassembled as mating surfaces are mated. |
Lo-Fi Version | Time is now: 20th May 2024 - 04:31 PM |
