What's the best way to store parts, Cosmoline spray? |
jsaum |
Oct 22 2016, 10:15 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I have two transmissions and a couple of spare motors that I want to break down so I can store them in the crawl space under my house. The wife says the garage needs to get cleaned up! It stays dry but there is a lot of moisture in the air what is the best way to keep the cases from corrosion? I was thinking cosmoline spray then putting the parts in heavy duty plastic bags and boxing them up. Is there something that's easier to clean up than cosmoline?
Jsaum |
jsaum |
Oct 23 2016, 10:42 PM
I found some tool and die long term anti rust spray online. I'm going to break the transmissions down and use the spray on them. I'll bag them up and store the housings in the crawl space. I'll store the rest of the gears in the garage. I've had some engine tins, axles and other parts stored there for over a year and they're ok so far. I'll keep a close eye on everything. I'll break the engines down to short blocks they should be easier to store in the garage.
Lo-Fi Version | Time is now: 17th May 2024 - 09:44 AM |
