Trouble with brake bleeding, I can't get any pressure in the system |
mobymutt |
Oct 23 2016, 04:29 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
If your bleed nipples are at the bottom of your calipers, that is at least a major part of your problem...period. Air bubbles rise in a liquid (brake fluid) so you'll never get them out if you don't have a high point in the system from which to purge them. I agree. Your fronts will still be almost full of air. |
Lozgib |
Oct 28 2016, 05:49 AM
Newbie Group: Members Posts: 5 Joined: 29-July 16 From: U.K. Member No.: 20,236 Region Association: None |
Well guys thanks for all the replies and advice. It WAS the two front brake callipers on the wrong side i.e. bleed nipples on the bottom not top. I've now got some brake pressure and although a bit spongy I now know I will get them sorted.
So thanks for pointing out re swapping the fronts to resolve main issue. I won't make that mistake again! |
Olympic 914 |
Oct 28 2016, 07:12 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I may get some abuse for this, but a way I have found to bleed the brakes with one person is to use the bleeder adapters from my Mity-Vac kit and the bottle that goes with it and instead of constantly pumping the Mity-Vac. I just hook it up to a shop vac. ( with a small hose adapter for detail work) unfortunately I didn't take any pictures of this Rube Goldberg contraption but it always keeps vacuum on the system. then I sit in the car and slowly pump the brakes. the vacuum keeps any air from getting back into the system, and pulls some fluid even when not pumping the brakes. be sure to check your master cylinder frequently as it can go down quickly.
Works for me. |
N_Jay |
Oct 28 2016, 07:32 AM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
Having re read Bartlet's reply. My bleed nipples are def at the bottom of the callipers so does this mean I've fitted the two front callipers the wrong way round? And would this be the problem. Thanks. DING DING DING! If the bleeders are at the bottom the caliper is still mostly full of air. |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:01 AM |
