Are head and cylinder gaskets compression gaskets? |
stevegm |
Oct 22 2016, 01:04 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I need to remove the heads off of a newly rebuilt engine (4-cylinder) I built (never run). They have already been torqued. Are the head gaskets and gasket between the cylinder and block, compression gaskets that should be thrown away (i.e., replaced with new one) after I untorque the heads?
The head gaskets will be easy to replace. But I'd have to pull the cylinders to replace the ones between them and the block. |
mbseto |
Oct 26 2016, 08:34 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
You can lead a human to knowledge, but you can't make them think. No one's led us to knowledge yet, they've just said 'do what I say'. I was hoping someone might address that question of whether the head and cylinders need to be lapped together. Can I do it by hand? Depending on the tools required, gaskets might be the option I can afford. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:38 AM |
