Steering wheel bolt patterns, Need some measurements |
Brett W |
Apr 20 2005, 07:44 AM
GOt a wheel off Evilbay and need to fit a hub and horn button to it. I need someone out there with a Personal, Momo, Sparco, etc wheel to measure the bolt pattern and horn button hole. Maybe I can avoid having to make my own.
ArtechnikA |
Apr 20 2005, 08:01 AM
the BHC specs have been posted here many times. does the wheel in question have a hole at 12 o'clock, or 11 & 1? that'll tell you the diameter. (Personal is one, Momo/Sparco is the other.) |
Jeroen |
Apr 20 2005, 08:51 AM
momo, sparco, etc... 6 x 70mm
the bolts start at 12 o-clock, then 2, 4, etc. personal, raid, fittipaldi, nardi, etc 6 x 74mm (or 75, can't remember off the top of my head) the bolts start at 1 o-clock, then 3, 5, etc. |
Brett W |
Apr 20 2005, 10:04 AM
Thanks guys, I'll check the wheel when I get back to the house.
Brett W |
Apr 20 2005, 05:48 PM
Looks like it would be a MOMO/Sparco pattern. Thanks for the help.
Lo-Fi Version | Time is now: 10th May 2024 - 09:17 AM |
