Steering wheel bolt patterns, Need some measurements |
Brett W |
Apr 20 2005, 07:44 AM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
GOt a wheel off Evilbay and need to fit a hub and horn button to it. I need someone out there with a Personal, Momo, Sparco, etc wheel to measure the bolt pattern and horn button hole. Maybe I can avoid having to make my own.
ArtechnikA |
Apr 20 2005, 08:01 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
the BHC specs have been posted here many times. does the wheel in question have a hole at 12 o'clock, or 11 & 1? that'll tell you the diameter. (Personal is one, Momo/Sparco is the other.) |
Jeroen |
Apr 20 2005, 08:51 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
momo, sparco, etc... 6 x 70mm
the bolts start at 12 o-clock, then 2, 4, etc. personal, raid, fittipaldi, nardi, etc 6 x 74mm (or 75, can't remember off the top of my head) the bolts start at 1 o-clock, then 3, 5, etc. |
Brett W |
Apr 20 2005, 10:04 AM
Thanks guys, I'll check the wheel when I get back to the house.
Brett W |
Apr 20 2005, 05:48 PM
Looks like it would be a MOMO/Sparco pattern. Thanks for the help.
Lo-Fi Version | Time is now: 20th May 2024 - 01:34 PM |
