2.0L D-Jetronic Distributors, Differences |
pbanders |
Oct 22 2016, 07:49 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I'm putting together some materials on 914 D-Jetronic distributors I hope to add to my web page soon (along with other updates). I have some questions regarding the 2.0L distributors.
Sources list the following distributors were used for the 2.0L across the model years: 1973: 039 905 205 (vac canister 022 905 271 C) 1974: 039 905 205A (vac canister 022 905 271) 1975-1976: 039 905 205B (vac canister 022 905 271) I have data for the mechanical advance curve for the 205 and 205A distributors, but not for the 205B distributor. Does anyone have a source for this information? I'm looking for the advance at 1500 and 3000 rpm. I have data for the vacuum advance and retard cells for both the 271 and 271 C canisters. Another question is the use of vacuum advance on various years of the 2.0L engines. IIRC, the vacuum advance was not connected on the 1975 and 1976 engines. There was a hose that came off of the throttle body (the port was still there), but it was capped and not connected to the vacuum advance cell of the distributor. Is this correct? Was it also disconnected on the 1974 2.0L engine? Thanks in advance for any help on these questions. |
Dr-DJet |
Oct 24 2016, 05:35 AM
Dr-DJet Group: Members Posts: 14 Joined: 21-May 16 From: around Frankfort, Germany Member No.: 20,021 Region Association: Germany |
I'm putting together some materials on 914 D-Jetronic distributors I hope to add to my web page soon (along with other updates). I have some questions regarding the 2.0L distributors. Sources list the following distributors were used for the 2.0L across the model years: 1973: 039 905 205 (vac canister 022 905 271 C) 1974: 039 905 205A (vac canister 022 905 271) 1975-1976: 039 905 205B (vac canister 022 905 271) Thanks in advance for any help on these questions. Hi Brad, I can help, but only if I know the Bosch nos. VW 0 39 905 205B should be Bosch 0 231 172 021. Can you confirm that? If yes, I will search for the curves. Regards from good old Germany, Dr-DJet Volker (IMG:style_emoticons/default/beer.gif) |
nordfisch |
Oct 24 2016, 07:19 AM
Member Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
I'm putting together some materials on 914 D-Jetronic distributors I hope to add to my web page soon (along with other updates). I have some questions regarding the 2.0L distributors. Sources list the following distributors were used for the 2.0L across the model years: 1973: 039 905 205 (vac canister 022 905 271 C) 1974: 039 905 205A (vac canister 022 905 271) 1975-1976: 039 905 205B (vac canister 022 905 271) Thanks in advance for any help on these questions. Hi Brad, I can help, but only if I know the Bosch nos. VW 0 39 905 205B should be Bosch 0 231 172 021. Can you confirm that? If yes, I will search for the curves. Regards from good old Germany, Dr-DJet Volker (IMG:style_emoticons/default/beer.gif) Hi Volker, according to the old Bosch list the Bosch #s should be: 1973: 039 905 205 (vac canister 022 905 271 C): 0 231 174 010 (009 without VW sign/logo), up to 1973/6 1974: 039 905 205A (vac canister 022 905 271): 0 231 174 012 (011 without VW sign/logo), 1973/7 to 1974/7 1975-1976: 039 905 205B (vac canister 022 905 271): 0231 172 022 (021 without VW sign/logo) 1974/8 to 1975/12 Regards Norbert - The distributors are not mentioned in the red Bosch D-Jetronic-manual at all - |
Lo-Fi Version | Time is now: 10th May 2024 - 09:26 AM |
