2.0L D-Jetronic Distributors, Differences |
pbanders |
Oct 22 2016, 07:49 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I'm putting together some materials on 914 D-Jetronic distributors I hope to add to my web page soon (along with other updates). I have some questions regarding the 2.0L distributors.
Sources list the following distributors were used for the 2.0L across the model years: 1973: 039 905 205 (vac canister 022 905 271 C) 1974: 039 905 205A (vac canister 022 905 271) 1975-1976: 039 905 205B (vac canister 022 905 271) I have data for the mechanical advance curve for the 205 and 205A distributors, but not for the 205B distributor. Does anyone have a source for this information? I'm looking for the advance at 1500 and 3000 rpm. I have data for the vacuum advance and retard cells for both the 271 and 271 C canisters. Another question is the use of vacuum advance on various years of the 2.0L engines. IIRC, the vacuum advance was not connected on the 1975 and 1976 engines. There was a hose that came off of the throttle body (the port was still there), but it was capped and not connected to the vacuum advance cell of the distributor. Is this correct? Was it also disconnected on the 1974 2.0L engine? Thanks in advance for any help on these questions. |
Dr-DJet |
Oct 24 2016, 09:34 AM
Dr-DJet Group: Members Posts: 14 Joined: 21-May 16 From: around Frankfort, Germany Member No.: 20,021 Region Association: Germany |
Hi Norbert,
thank you. Bosch Automotive Tradition's website was without Search function this morning, that is why I could not find the info myself. Okay, well then. 0 231 172 021 or 022 has following data: - Centrifugal from 1000 to 2600 rpm by 22° early - vacuum in idle by 10° late - vacuum load dependent from 120 mmHg to 200 mmHg by 12° early All advances are in degree crankshaft. Bosch denotes them for ignition distributor test stands in ° camshaft. Hope that helps. Best regards from Germany, Dr-DJet Volker |
pbanders |
Oct 24 2016, 11:42 AM
Hi Norbert, thank you. Bosch Automotive Tradition's website was without Search function this morning, that is why I could not find the info myself. Okay, well then. 0 231 172 021 or 022 has following data: - Centrifugal from 1000 to 2600 rpm by 22° early - vacuum in idle by 10° late - vacuum load dependent from 120 mmHg to 200 mmHg by 12° early All advances are in degree crankshaft. Bosch denotes them for ignition distributor test stands in ° camshaft. Hope that helps. Best regards from Germany, Dr-DJet Volker Thanks, that's just the information I was looking for. |
Lo-Fi Version | Time is now: 10th May 2024 - 12:00 PM |
