2.0L D-Jetronic Distributors, Differences |
pbanders |
Oct 22 2016, 07:49 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I'm putting together some materials on 914 D-Jetronic distributors I hope to add to my web page soon (along with other updates). I have some questions regarding the 2.0L distributors.
Sources list the following distributors were used for the 2.0L across the model years: 1973: 039 905 205 (vac canister 022 905 271 C) 1974: 039 905 205A (vac canister 022 905 271) 1975-1976: 039 905 205B (vac canister 022 905 271) I have data for the mechanical advance curve for the 205 and 205A distributors, but not for the 205B distributor. Does anyone have a source for this information? I'm looking for the advance at 1500 and 3000 rpm. I have data for the vacuum advance and retard cells for both the 271 and 271 C canisters. Another question is the use of vacuum advance on various years of the 2.0L engines. IIRC, the vacuum advance was not connected on the 1975 and 1976 engines. There was a hose that came off of the throttle body (the port was still there), but it was capped and not connected to the vacuum advance cell of the distributor. Is this correct? Was it also disconnected on the 1974 2.0L engine? Thanks in advance for any help on these questions. |
N_Jay |
Oct 24 2016, 09:45 AM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
(Caution: Stupid Off-Topic question below!)
Is there a significant different between D-Jet and L-Jet distributers? |
Dr-DJet |
Oct 24 2016, 09:56 AM
Dr-DJet Group: Members Posts: 14 Joined: 21-May 16 From: around Frankfort, Germany Member No.: 20,021 Region Association: Germany |
(Caution: Stupid Off-Topic question below!) Is there a significant different between D-Jet and L-Jet distributers? For sure: D-Jetronic distributors carry trigger points for injectors. (IMG:style_emoticons/default/w00t.gif) Secondly during the time of K-Jetronic and L-Jetronic breakerless ignition distributors were introduced. But I am not too sure when that was started in 914. Mercedes switched from breaker-controlled transistor igntion to breakerless transistor ignition when they switched from D-Jetronic to K-Jetronic. Best regards from Germany, Dr-DJet Volker |
N_Jay |
Oct 24 2016, 01:56 PM
(Caution: Stupid Off-Topic question below!) Is there a significant different between D-Jet and L-Jet distributers? For sure: D-Jetronic distributors carry trigger points for injectors. (IMG:style_emoticons/default/w00t.gif) Secondly during the time of K-Jetronic and L-Jetronic breakerless ignition distributors were introduced. But I am not too sure when that was started in 914. Mercedes switched from breaker-controlled transistor igntion to breakerless transistor ignition when they switched from D-Jetronic to K-Jetronic. Best regards from Germany, Dr-DJet Volker I am fairly sure the L-Jet 914 are still conventional ignition? I could be wrong, but thought it still have FI timing in the dist. |
Lo-Fi Version | Time is now: 9th May 2024 - 05:55 PM |
