Central deposit, Attachment of the deposit to the dashboard |
erwindv |
Oct 23 2016, 10:30 AM
Newbie Group: Members Posts: 46 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
Hey all,
Could somebody post some pics on how the central deposit of a 71 is attached to the dash? Please, if possible, from different angles and with measures of the latch, holding the deposit. Thanks a lot in advance, Erwin (IMG:style_emoticons/default/beerchug.gif) |
gcrotvik |
Oct 24 2016, 10:09 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Hey all, Could somebody post some pics on how the central deposit of a 71 is attached to the dash? Please, if possible, from different angles and with measures of the latch, holding the deposit. Thanks a lot in advance, Erwin (IMG:style_emoticons/default/beerchug.gif) It's not attached to the dash directly. The top bracket is attached to the inner bulkhead with two screws. There should be two plastic inserts that attach to the body through the bulkhead. The picture below is from my 74 as it went to the body/paint shop. It doesn't have the plastic inserts installed but you can see the location. The later 2.0 center console attaches here also. Greg Attached image(s) |
914_teener |
Oct 25 2016, 10:56 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
erwindv |
Oct 26 2016, 12:59 AM
Indeed, this is the one.
Mine is for the moment in the same condition as yours, needs a clean up. As in my car, the bracket is missing, I am especially interested on how the bracket looks like and the way it is attached to the inner bulkhead. Erwin |
914_teener |
Oct 26 2016, 09:52 AM
Indeed, this is the one. Mine is for the moment in the same condition as yours, needs a clean up. As in my car, the bracket is missing, I am especially interested on how the bracket looks like and the way it is attached to the inner bulkhead. Erwin Ok...then do you want just the bracket detail? Do you still want to measure the side peices? Let me know. |
erwindv |
Oct 26 2016, 12:18 PM
Indeed, this is the one. Mine is for the moment in the same condition as yours, needs a clean up. As in my car, the bracket is missing, I am especially interested on how the bracket looks like and the way it is attached to the inner bulkhead. Erwin Ok...then do you want just the bracket detail? Do you still want to measure the side peices? Let me know. Some foto's of the bracket and the way it is attached to the bulkhead are OK. If possible, can you give the measurements of the bracket so I can reproduce it? Thanks a lot Erwin |
Lo-Fi Version | Time is now: 24th April 2024 - 05:42 AM |
