Powdercoating is awesome... even WITHOUT an oven!, with promised pictures. |
Lawrence |
Jun 24 2003, 11:22 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
I'm about 3 hours into my first powdercoating adventure. Man, this stuff rocks. Again, Ginter is right. If you have a garage, and don't have your own setup - you might want to rethink that.
My setup from Columbia Coating, including about 8 pounds of various metallics/clears was about 200 bucks. Pam picked up some extra natural corks (because she saw it on American Chopper). They seem to work as well as the synthetic/plastic corks for plugging bolt holes. I will post pictures later... gotta get back out and monitor temps. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lawrence |
Jun 26 2003, 04:04 PM
Spraying an A-Arm.
Please note the "ground strap" hooked to the end. 1. Grounding points don't work well through masking tape. 2. If your hanging hook contacts the metal part directly, you can ground on the hook. That's often much easier. 3. You need to be creative with your hanging methods. I plugged the ends of the A-Arm and then jammed the hooks into the plugs. 4. Wherever you hang an item will leave a small dimple during the curing process, obviously. Attached image(s) |
Lo-Fi Version | Time is now: 25th May 2024 - 07:10 AM |
