Not shifting well |
Not shifting well |
vin man |
Oct 25 2016, 01:08 PM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
The 71 that I just purchased with Subaru EJ25 and sideshifter trans is not shifting properly. Won't stay in 4th or 5th gear. I suspect the shifter linkage between the firewall and the transmission as what is installed now looks like hillbilly engineering.
I've reached out to Renegade Hybrids to see what they offer for a linkage since the conversion is using Renegade's cradle and adapters. But I'm also considering a new shifter. What does this group recommend for a decent shifter that has a shorter throw than the original? |
Rand |
Oct 27 2016, 04:45 PM
At least verify adjustments and that everything is tight before throwing parts at it. There are many threads around here on how to adjust linkage that would be worth searching out.
(IMG:style_emoticons/default/beerchug.gif) |
vin man |
Oct 27 2016, 04:52 PM
At least verify adjustments and that everything is tight before throwing parts at it. There are many threads around here on how to adjust linkage that would be worth searching out. (IMG:style_emoticons/default/beerchug.gif) Thanks. I've viewed a few of those threads. Seems like my issue is with this piece in particular. when I try to move the connection on the rod further towards rear of car, this piece just angles more and I still can't get 4th gear to stay without holding it. (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1477608721.1.jpg) |
Lo-Fi Version | Time is now: 26th May 2024 - 01:00 PM |
