Not shifting well |
Not shifting well |
vin man |
Oct 25 2016, 01:08 PM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
The 71 that I just purchased with Subaru EJ25 and sideshifter trans is not shifting properly. Won't stay in 4th or 5th gear. I suspect the shifter linkage between the firewall and the transmission as what is installed now looks like hillbilly engineering.
I've reached out to Renegade Hybrids to see what they offer for a linkage since the conversion is using Renegade's cradle and adapters. But I'm also considering a new shifter. What does this group recommend for a decent shifter that has a shorter throw than the original? |
Bob L. |
Oct 28 2016, 08:46 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
(IMG:style_emoticons/default/blink.gif)
Hard to tell for sure from the pix but it looks like it would be better to run the shift rod through the hole in the gusset on the cradle. Not that that would be the best option overall. I like the cable shift solution. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:48 PM |
