3 Pages V < 1 2 3 >
> Help us rebuild a 1.7, We have no idea what we're doing, but its fun!
ericoneal
post Nov 6 2016, 04:08 PM
Post #21
Great link, looks like lots of good info there. THanks for that.
WOuld love to get my hands on the BugMe DVD as well if you are finished with it.
Still looking at getting the engine moved down to my basement and onto a stand, unfortunately, I threw my back out a few days ago, so that is causing delays.
QUOTE(NCRider @ Nov 5 2016, 09:34 AM) *
Eric I think I have a extra Bug Me DVD i can give you . The late Bob Hoover's Blog has a great deal of practical air cooled motor information.
http://bobhooversblog.blogspot.com/search?q=cylinder+height+
Jeff
NCRider
post Nov 7 2016, 07:37 AM
Post #22
I found my other Bug Me copy. PM me the address and I'll get it out to you.
Jeff
NCRider
post Nov 15 2016, 02:58 PM
Post #23
QUOTE(NCRider @ Nov 7 2016, 08:37 AM) *
Jeff
Eric I got the DVD mailed out today. You should have it by the end of the week.
Jeff
stugray
post Nov 15 2016, 03:29 PM
Post #24
I also have a spare Jake Raby video.
I bought one, misplaced it, bought another, found original....
Frankvw
post Nov 29 2016, 06:41 AM
Post #25
working on my first 914 !
Region Association: Europe
Hi guys, how is your build coming along ? Any updates ?
ericoneal
post Nov 29 2016, 09:03 AM
Post #26
Slow going, but I did receive the rebuild DVD in the mail yesterday. Thanks NCRider!
I'm still trying to get my neighbor to help with moving onto the engine stand, then i will send more pictures. Head and cyclinders, etc are in plastic bins and the shortblock is still sitting. I thought if I got all of the extraneous stuff off that I could move it myself, but its heavy and I dont think I can get it to the basement alone.
Everything is set to go, but life keeps happening...
ericoneal
post Dec 14 2016, 08:14 AM
Post #27
We're finally on the engine stand. More to come....
(Yes thats a plastic monkey wrench hanging off)
IronHillRestorations
post Dec 14 2016, 02:25 PM
Post #28
I. I. R. C.
Have you found anything obviously wrong? IIRC it was #3 that had low compression. Looks like your boy is enjoying the process (IMG:style_emoticons/default/smile.gif)
ericoneal
post Dec 14 2016, 06:31 PM
Post #29
Not sure what to look for, but will post picks of everything. Heads are off and cylinders are out at this point.
ericoneal
post Jan 3 2017, 09:03 AM
Post #30
Pistons are off! How do they look?
The clips holding them on were very hard to remove. Splitting the case open tonight! Attached Image
malcolm2
post Jan 3 2017, 09:11 AM
Post #31
QUOTE(ericoneal @ Jan 3 2017, 09:03 AM) *
Go slowly on splitting the case. Lots of hidden bolts. don't get too physical and try to wedge it apart. If it does not come easily, you have a nut left to get.
If you had low compression, were the rings stuck on that cylinder?
What about a photo of the heads? My problem was obvious. One of the valve seats had broken and gotten into the combustion chamber and bounced around, ruining the piston and the head.
ericoneal
post Jan 3 2017, 09:37 AM
Post #32
I will post detailed pictures of the heads tonight, been meaning to do that. I think the internals may be OK, but I want to split the case open out of curiosity, if all is well, I will just leave it alone.
Can you elaborate by "rings stuck on the cylinder"? Is there something I should look for? Will post pictures of those as well.
Thanks
malcolm2
post Jan 3 2017, 10:23 AM
Post #33
QUOTE(ericoneal @ Jan 3 2017, 09:37 AM) *
Thanks
Rings stuck. I was thinking you could have a low compression cylinder. Maybe a ring problem. I have seen rings that have come out of their channel and bent. Maybe a ring broke and did not seal properly, or stuck to the inside of it's channel and did not touch the wall of the cylinder.
Any reason to not show compression.
ericoneal
post Jan 12 2017, 11:05 AM
Post #34
Blake took the thermostat and oil pump cover off last night before the magnets we were going to use to remove the lifters got all of his attention.
This looks like a Type1 oil pump to me, am I right?
Also, can anyone identify these pistons from their markings?
Thanks, slowly making progress..
post Jan 12 2017, 01:20 PM
Post #35
I. I. R. C.
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
Al Meredith
post Jan 12 2017, 05:32 PM
Post #36
Something doesn't look right. All the 1.7s I've rebuilt have domed pistons. The pistons pictured in this thread appeared to be "dished" or lower compression. Could hat be a bus or 411 engine?
ericoneal
post Jan 12 2017, 09:55 PM
Post #37
I noticed that too, could be bus pistons for sure. I've heard of them being used because they are cheap.
ericoneal
post Jan 26 2017, 11:37 AM
Post #38
We got the case open!
Confirmed that it is a 1.7 engine, but case has a bronzish tint to it. Wonder if it was recently rebuilt or mucked with because everything has come apart pretty easily. (ie bolts not stuck, etc).
Lots of oil and dirt on it though, so I need to figure out to get this thinged cleaned up. Anyone ever take their case to the car wash and use the pressure washers there?
Frankvw
post Jan 26 2017, 01:01 PM
Post #39
you guys are doing a great job.
Over here: If I would take a oily case to the pressure washer station I hope I do not get caught for environmental hazard violation.....
Keep up the good work ! Looking forward to more updates !
Valy
post Jan 26 2017, 01:06 PM
Post #40
Let me be the first one to tell you that your cam is dead.
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 16th April 2024 - 11:05 AM
