Brakes are killing my leg....major pressure needed to stop the car. |
carcus |
Oct 26 2016, 09:55 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Brakes sucked when I got the car, leaking caliper, bad master. Got all new wheel bearings, new rotors, pads, master. No leaks in the system. I have to mash the brake pedal down and it still takes lots of effort to stop. My last 914 was not like this. The mechanic adjusted them but think he forgot to check the pedal adjustment. Any tips to this? Am I missing something. This is about the brake pedal movement to stopping the car. Even at a red light I need to use alot of pressure to keep the car from rolling. The brake pedal should not have that much effort. Really makes the car not fun to drive. And there is really no bite to the calipers to slow it down if I have to slam on the brakes.
Dave_Darling |
Oct 26 2016, 10:22 PM
Get rid of that Mercedes 23mm master cylinder. Switch back to a 914 17mm one.
Actually, I'm guessing you have a 19mm one? The 17mm one will require about 25% less effort for the same stopping force. Also check that the floor that the master cylinder bolts to isn't flexing--McMark and Racer Chris both make braces to help keep the MC from moving. And check your brake lines when someone stands on the pedal. --DD |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:04 AM |
