Brakes are killing my leg....major pressure needed to stop the car. |
carcus |
Oct 26 2016, 09:55 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Brakes sucked when I got the car, leaking caliper, bad master. Got all new wheel bearings, new rotors, pads, master. No leaks in the system. I have to mash the brake pedal down and it still takes lots of effort to stop. My last 914 was not like this. The mechanic adjusted them but think he forgot to check the pedal adjustment. Any tips to this? Am I missing something. This is about the brake pedal movement to stopping the car. Even at a red light I need to use alot of pressure to keep the car from rolling. The brake pedal should not have that much effort. Really makes the car not fun to drive. And there is really no bite to the calipers to slow it down if I have to slam on the brakes.
jcd914 |
Oct 27 2016, 06:03 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Years ago, I replaced the brake pads (frt & rr) on a 914 and the car just would not stop well. The pedal feel was fine, no air, no slop, nice firm pedal when you stepped on it.
The pads were a no name brand, came in plain white box (we had a service manager that kept trying to save a buck or two) and they just had no bite to them. I went thru the bedding in process, still no good. I finally convinced the Service Manager that we needed to put in different pads. I swapped the pads out for some Textar pads and we had good brakes again. Jim |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:17 AM |
