Hot Voltage Regulator? |
MikeM |
Oct 27 2016, 05:51 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...I checked my charging voltage at the battery and it was high. It was almost 16.
So I went to install my spare and the regulator was very hot!! I've never noticed before because I never checked!! Should it be hot? I installed my spare and it allowed a charge rate of 13.4 but it also began to get hot. Hope my alternator isn't bad!! Cheers Mike |
oakdalecurtis |
Oct 29 2016, 02:49 PM
Oakdalecurtis Group: Members Posts: 1,326 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Before doing anything else, lift your relay board and look at the underside. The tar sealing can and will melt away which leaves the receptive electrical contacts inneffective. I had the same over charging problem, replaced relay board, all fixed!
Lo-Fi Version | Time is now: 20th May 2024 - 08:15 AM |
