L-Jet throttle body question |
Rob-O |
Nov 1 2016, 10:24 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
New spring installed.
Still runs way rich, low stumbling idle during warm up. Once it's warm it runs good. Checked CHT, temperatures weren't exactly at 68 deg. F and 176 deg. F, but at 68 deg. F it was at ~1700 ohms when it should've been at 2200-2300. Have a new CHT coming from the group buy, we'll see if that helps. Attached thumbnail(s) |
timothy_nd28 |
Nov 1 2016, 11:10 PM
Did this running rich issue happen after you installed the pretty throttle body? The lower resistance from the CHT sensor simulates a warmer engine, which should be a leaner enrichment from the ECU.
Rob-O |
Nov 2 2016, 06:30 AM
Nope. It's been there since I switched from carbs back to FI.
ClayPerrine |
Nov 2 2016, 11:33 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I helped Rob with the reinstallation of the Fuel injection. I checked the FI harness, and all the connections.
It is possible he has a mismatched ECU. Rob, Send me the part number off the ECU on your car. I will check it against the one in Betty's car. Clay |
Rob-O |
Nov 2 2016, 12:10 PM
Will do.
I checked the boot from the AFM to the TB and *thought* it was okay too. I just pulled the AAV and checked that. It's good. When I reinstalled I used clamps on all of the connections from there to the elbow. The line from the boot to the oil fill tower is also clamped. |
Rob-O |
Nov 2 2016, 03:57 PM
ECU
Lo-Fi Version | Time is now: 2nd June 2024 - 05:50 AM |
