WTB : BMW 320i front calipers for my 914 |
Korijo914 |
Oct 31 2016, 04:40 PM
Newbie Group: Members Posts: 24 Joined: 26-April 16 From: Snohomish WA Member No.: 19,940 Region Association: None |
Hello fellas,
I am ( still ) looking for some BMW 320i front calipers for my 914. If anyone has a set, please, PLEASE let me know! Thanks again, David ( korijo 914 ) Cawdrey |
BigFour1973 |
Oct 31 2016, 05:01 PM
Member Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California |
https://www.napaonline.com/napa/en/p/SEBSE7...E775_0206190752
https://www.napaonline.com/napa/en/p/SEBSE7...E776_0206375496 They're fairly cheap as a reman'd set too. Make sure you make the correct modification to the caliper if you have 72-76 front suspension Edit: now I see they're out of stock.... Try this source, says it's able to ship..... http://www.oreillyauto.com/site/c/search/B...&vi=1011485 |
Korijo914 |
Oct 31 2016, 05:11 PM
https://www.napaonline.com/napa/en/p/SEBSE7...E775_0206190752 https://www.napaonline.com/napa/en/p/SEBSE7...E776_0206375496 They're fairly cheap as a reman'd set too. Make sure you make the correct modification to the caliper if you have 72-76 front suspension Edit: now I see they're out of stock.... Too bad they are out of stock! Then, how do I modify them? Diddo ! |
BigFour1973 |
Oct 31 2016, 05:16 PM
https://www.napaonline.com/napa/en/p/SEBSE7...E775_0206190752 https://www.napaonline.com/napa/en/p/SEBSE7...E776_0206375496 They're fairly cheap as a reman'd set too. Make sure you make the correct modification to the caliper if you have 72-76 front suspension Edit: now I see they're out of stock.... Too bad they are out of stock! Then, how do I modify them? Check out my most recent edit, Orileys says they have them available to ship. http://www.pelicanparts.com/techarticles/9...MW_calipers.htm About 1/3 the way through the article it talks about the modification necessary |
BigFour1973 |
Oct 31 2016, 05:17 PM
Also they must be ATE calipers, NOT the Girling type
bdstone914 |
Oct 31 2016, 05:51 PM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
BigFour1973 |
Oct 31 2016, 06:00 PM
Also they must be ATE calipers, NOT the Girling type That is not true. The Girling calipers need to be modify the same way the ATE calipers do. I have done both. I could have another set modified and rebuild them. Bruce Ahhh, I see. The pelican article says to use the ate and not the girling. Thanks for clearing that up (IMG:style_emoticons/default/beerchug.gif) |
Korijo914 |
Oct 31 2016, 07:57 PM
Also they must be ATE calipers, NOT the Girling type That is not true. The Girling calipers need to be modify the same way the ATE calipers do. I have done both. I could have another set modified and rebuild them. Bruce Bruce, Are they for solid rotors or vented rotors? Please let me know when they are ready for sale! I am looking for something. I really don't want to buy an entire front suspension from a 911...! Ugh korijo 914 |
djway |
Nov 1 2016, 01:55 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
I purchased a pair on Amazon, took the instructions to a local machine shop and had them modified.
You then need another brake line that you bend to fit. I also added the 19mm master cylinder. Not that hard. |
B2524 |
Nov 1 2016, 09:23 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
I had a set of struts from a 69 912 that used Koni inserts. I used them on my 914 with 914 rotors and 912 hubs. Everything bolted together, no machining and converted to 5 lug using left over parts.
Oh yeah I used BMW calipers too. |
bdstone914 |
Nov 1 2016, 10:06 PM
I had a set of struts from a 69 912 that used Koni inserts. I used them on my 914 with 914 rotors and 912 hubs. Everything bolted together, no machining and converted to 5 lug using left over parts. Oh yeah I used BMW calipers too. What 914 rotors can be bolted to 912 hubs?(IMG:style_emoticons/default/confused24.gif) Maybe 911 solid rotors? |
Lo-Fi Version | Time is now: 15th May 2024 - 11:48 PM |
