Rear Sway Bar attaching parts WTB |
kaiserms |
Oct 31 2016, 09:26 PM
MSKaiser Group: Members Posts: 26 Joined: 8-September 16 From: waterford, michigan Member No.: 20,378 Region Association: Upper MidWest |
WTB: Attachment pieces for '73 2.0 rear sway bar
Shown in AutoAtlanta "Hard Parts" Rear Suspension numbered 25,28,29 Part #90133375301 Supporting Bow (2) Part #91450125911GRV Mounting Plate (2) Part # 91450153271 Reinforcement Hoping someone has some spare parts around. Thanks, KaiserMS |
Mark Henry |
Oct 31 2016, 09:38 PM
WTB: Attachment pieces for '73 2.0 rear sway bar Shown in AutoAtlanta "Hard Parts" Rear Suspension numbered 25,28,29 Part #90133375301 Supporting Bow (2) Part #91450125911GRV Mounting Plate (2) Part # 91450153271 Reinforcement Hoping someone has some spare parts around. Thanks, KaiserMS There's not much to them I just made my own. The reinforcement and mount need to be welded in. |
ConeDodger |
Oct 31 2016, 10:47 PM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Three sources:
High Performance House - Redwood City, CA EASY - Emeryville, CA Bruce Stone - right here. (Just put a WTB ad in the classifieds and he'll find you) Ok, four... Parts Heaven - Hayward, CA |
914Sixer |
Nov 1 2016, 06:06 AM
Madog has the kit you need. Bracket, plate and bolts for $55 dollars. You will have to source the supporting bracket. They are about $13-$20 depending on where you shop.
BillC |
Nov 1 2016, 07:03 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Tangerine Racing also has the weld-in mounts: http://www.tangerineracing.com/antiswaybars.htm
914work |
Nov 1 2016, 07:17 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Do you mean #30 (guide plates 2 required per arm)?
I think #29 is just a bolt. PM sent Attached image(s) |
Cairo94507 |
Nov 1 2016, 07:28 AM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
914werke - He needs the rear bar attachments. (IMG:style_emoticons/default/biggrin.gif)
914work |
Nov 1 2016, 07:29 AM
DOH!
cwpeden |
Nov 1 2016, 07:53 AM
Who needs a rear bar? After 200lb springs it hindered performance. (IMG:style_emoticons/default/cool.gif)
914_teener |
Nov 1 2016, 06:36 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Who needs a rear bar? After 200lb springs it hindered performance. (IMG:style_emoticons/default/cool.gif) (IMG:style_emoticons/default/agree.gif) But good luck with your project. |
Lo-Fi Version | Time is now: 14th May 2024 - 09:28 AM |
