Rocker Arm Spring Washer, Is it needed |
NJTom |
Nov 3 2016, 12:08 PM
Member Group: Members Posts: 92 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None |
We are assembling a 1974 2.0 motor and ran into a small problem. One side had washers which we identified as "thrust" washers. on the rocker arms while the other did not. See pictures below. Research says they were discontinued (maybe replaced in the mid 70's) can someone tell if they are needed or not? Thanks inasvance.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 05:08 PM |
